Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 07-30-2008, 01:04   #16 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,117
This will never work...
1. Because Logics inside VSPEC CPLD is not the same with Logics inside
AdvanceBB5 / AdvanceUFS CPLD.
2. Because the encryption used by VSPEC for the ADx triggers are not the
same with the encryption used by AdvaceBB5 / AdvanceUFS for the ADx triggers.
3. Because command set used by VSPEC CPLD to communicate with the PC
is not the same with the command set used by AdvanceBB5 / AdvanceUFS
for communicating with the PC.
4. Because protocol used by VSPEC CPLD to communicate with JAF box is
not the same with the protocol used by AdvanceUFS for communicating with
UFS box.
Cracked software will only work with Original AdvanceUFS Box. It is really
not possible to use any other box with cracked software. Maybe you can
backup PM, PMM, factory settings etc... with cracked software and you may
also be lucky enough to unlock old 6630, 6680 phones. But if you expect
that cracked software will enable you to unlock 6300 without buying the
original AdvanceBB5 or AdvanceUFS boxes, then I am afraid that you will
be truly disappointed.
@DYNET
Please do some research about Xilinx Coolrunner II CPLDs before posting.
Google is your friend.
Lastly, why would you want to use your 100% original VSPEC Box with
10% working AdvanceBox crack? Why don't you use 100% original VSPEC
software???
B.R.
X-Shadow
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 07-30-2008, 01:37   #17 (permalink)
Member: 578135
Thanks Meter: 13
UFS box.
@DYNET
software???
B.R.
X-Shadow
I have JAF PLUS and is a bad box, always have error in unlock process: 07 or 08.
Old 07-30-2008, 03:51   #18 (permalink)
Temporary banned !!
Member: 808577
Thanks Meter: 639
Originally Posted by TDKI View Post
We tryed with a xilinx CPLD using VSPEC this is the result.
We tested the CRACK with UFS and Vspec to see what we can do. We got as far as connect TP. We connected TP and VSPEC did not see TP.
We needed to know if the software was given the problem. So we switch to AdvanceBOX and unlocking worked 100% using crack. Which means that the Crack software is working 100% all features working.
The Conclusion: is some one needs to modifying Vspec box or testpoint. To work 100% with CRACK.
Old 07-30-2008, 04:00   #19 (permalink)
wecxs's Avatar
Member: 331397
Thanks Meter: 26
can i use jaf plus insted of v-spec....????????
Old 07-30-2008, 04:22   #20 (permalink)
Temporary banned !!
Member: 808577
Thanks Meter: 639
If you have jaf plus and ABB5 crack it only takes about 5 mins to test. Test it and see. And post results.. we are intrested...
Old 07-30-2008, 05:05   #21 (permalink)
Member: 651945
@TDKI
Thanks for sharing your findings and showing a great deal of interest to our product.
But like I said, different CPLD Logics inside VSPEC and AdvanceUFS and different
protocol + trigger encryption as well. So you have zero chances of TP unlocking using
our software + third party box.
B.R.
X-Shadow
Old 07-30-2008, 05:41   #22 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
if wana -=Feel the Power =- use Original
after all ur great playing with great vspec and advance box so called cracked result might be a big BRICK
the real question is why BB5box and Vspec users need Advance Box Soft ???????
Old 07-30-2008, 09:34   #23 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,920
Thank You..........
UFS box.
@DYNET
software???
B.R.
X-Shadow
DEAR THIS IS ONLY TESTING PURPUS ONLY AND FOR UNLOCK WE HAVE ALL BOX WHICH IS IN MARKET THISH IS JUST TESTING OR NOW WHO IS CRAKER COME HERE YOU HAVE POINT FOR NEXT CRACK SEE THIS
UFS box.
BR.DYNET
Old 07-30-2008, 16:38   #24 (permalink)
Temporary banned !!
Member: 808577
Thanks Meter: 639
@TDKI
B.R.
X-Shadow
It is a interesting problem and a good learning tool. So what we learn is the AdvanceBOX Software for the second time was Cracked and is working 100%. That we can connect UFS to VSPEC with CRACK with no-problem. That the firmware/protocol message set in Vspec is different then AdvanceBOX so is not a hardware problem. A question comes to mind can VSPEC be flashed with AdvanceBOX firmware...
Old 08-01-2008, 18:56   #25 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
Advance-Box wrote,
"Lastly, why would you want to use your 100% original VSPEC Box with
software???"
very nice point. A great slap to DYNET.
Old 08-02-2008, 03:42   #26 (permalink)
Member: 651945
@TDKI
"It is a interesting problem and a good learning tool. So what we learn is the AdvanceBOX Software for the second time was Cracked and is working 100%."
Yes, and for the second time the crack is only 100% working if you have
100% ORIGINAL BOX. Otherwise 0% success of TP Unlocking if you try to use 3rd party TP
Boxes. What crackers fail to realize is that it is not the EXE that is doing the unlocking, but it
is the box doing it.
"That we can connect UFS to VSPEC with CRACK with no-problem."
You can even connect your VSPEC to the RJ-45 LAN Port of
your Laptop without encountering any problems.
"[I[That the firmware/protocol message set in Vspec is different then AdvanceBOX so is not a hardware problem.[/I]"
Really? I mean you did not even notice that AdvanceUFS
has a 1.8432 Mhz oscillator and VSPEC don't have it? So this is not a "Hardware"
issue even if this oscillator is used for communicating with the CPLD?
"A question comes to mind can VSPEC be flashed with AdvanceBOX firmware..."
It is not possible to flash AdvanceUFS xc2c256 firmware into
VSPEC xc2c128 CPLD. For very obvious reasons, AdvanceUFS CPLD is twice the size
of VSPEC CPLD... It just would not fit... period.
Use V-spec As Advancebox ........ ( Testing....) 2 DYNET J.A.F. By Jafsupport.com 0 07-28-2008 18:36
Use V-spec As Advancebox ........ ( Testing....) DYNET Nokia Base Band 5 ( BB-5 ) 0 07-28-2008 18:32
is V600 CID49 test point the same as K608 test point !!! the new SonyEricsson (USB-Smart) 0 12-26-2005 12:03
Page generated in 0.20236 seconds with 10 queries
