12-05-2007, 17:34 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | Rm-164 8600 -luna Unlock In 5 Minutes JAF version 1.98.41 Detected PKEY: Card life counter: 86.11% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: F:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: F:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: F:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: F:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 03.52 24-05-07 RM-164 (c) Nokia. HW version: 4000 PCI version: RFIC version: 17211721 DSP version: rm164_dsprap_pb05wk46v31_02 PPM version: V 03.52 24-05-07 RM-164 (c) Nokia. C Retu version: 32 Tahvo version: 53 Content Pack version: Content: voda_uk V 03.52 24-05-07 RM-164 (c) Nokia. Production serial number: MYG795713 Product code: 0551946 Module code: 0203066 Basic production code: 0532835 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356287011674069 IMEI spare to net: 3A 65 82 07 11 76 04 06 IMEI SV to net: 33 65 82 07 11 76 04 06 F4 LOCK STATUS: CONFIG KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 3, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Searching for saved ini... Checking for file F:\Program Files\ODEON\JAF\JAF_RM-164.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0551946 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backing up CRT data... Setting FLASH MODE Error sync the phone... Failed to backup CRT... Backup simlock data first... Setting local mode... Reading IMEI... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... F:\Program Files\ODEON\JAF\ProgData\RM-164_356287011674069_03.52_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 3, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Reading phone...Type: RM-164, Ver: 03.52 Reading imei... Imei: 356287011674069 Waiting for TP confirmation...................................... .................................................. .................................................. .................................................. ...............................................Sen ding code... Unlock OK! LOCK STATUS: CONFIG KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN |
12-06-2007, 08:07 | #4 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @n80 rm-92 in 15 minutes Code: Reading... Phone type: RM-92, Software version: 05wk33v33.1 IMEI: 358361006717767 APE Ver: (null) Variant Ver: (null) Product Code: 0535062 Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk33v33.1 22-06-06 RM-92 (c) Nokia. HW version: 6002 PCI version: RFIC version: 17191719 DSP version: miro_05wk32v37b Retu version: 14 Tahvo version: 21 Production serial number: SEJ241148 Product code: 0535062 Module code: 0202689 Basic production code: 0522205 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358361004179697 IMEI spare to net: 3A 85 63 01 40 71 69 09 IMEI SV to net: 33 85 63 01 40 71 69 09 F0 LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23420F Block 2: Lock 1: CLOSED -> Lock Data: 23420F Block 3: Lock 1: CLOSED -> Lock Data: 23594F Block 4: Lock 1: CLOSED -> Lock Data: 23594F Searching for saved ini... Checking for file F:\Program Files\ODEON\JAF\JAF_RM-92.ini Saved INI not found, loading INI list... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backing up CRT data... Setting FLASH MODE Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... Reading CMT CCC certificate... CCC not available... Reading CMT HWC certificate... HWC not available... Saved to F:\Program Files\ODEON\JAF\ProgData\35836100417969_CRT_backup_229212.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... F:\Program Files\ODEON\JAF\ProgData\358361004179697_CRT_backup_229212.pm Done! Backup LCK OK! Manual mode selected, version can't be checked! Done! Total time: 0 Minutes, 0 Seconds DCT4/BB5 counter: 10 After flash processing... Waiting for phone to boot... Reading... Phone type: RM-92, Software version: 05wk33v33.1 IMEI: 358361004179697 APE Ver: V 4.0623.0.41 26-07-2006 RM-92 Variant Ver: V 4.0623.0.41-11 26-07-2006 RM-92 Product Code: 0535062 Done! Backup simlock data first... Setting local mode... Reading IMEI... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... F:\Program Files\ODEON\JAF\ProgData\RM-92_358361006717767_05wk33v33.1_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23420F Block 2: Lock 1: CLOSED -> Lock Data: 23420F Block 3: Lock 1: CLOSED -> Lock Data: 23594F Block 4: Lock 1: CLOSED -> Lock Data: 23594F Reading phone...Type: RM-92, Ver: 05wk33v33.1 Reading imei... Imei: 358361006717767 Waiting for TP confirmation....................................................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Done! Backup simlock data first... Setting local mode... Reading IMEI... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... F:\Program Files\ODEON\JAF\ProgData\RM-92_358361004179697_05wk33v33.1_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23420F Block 2: Lock 1: CLOSED -> Lock Data: 23420F Block 3: Lock 1: CLOSED -> Lock Data: 23594F Block 4: Lock 1: CLOSED -> Lock Data: 23594F LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 1, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23420F Block 2: Lock 1: CLOSED -> Lock Data: 23420F Block 3: Lock 1: CLOSED -> Lock Data: 23594F Block 4: Lock 1: CLOSED -> Lock Data: 23594F Reading phone...Type: RM-92, Ver: 05wk33v33.1 Reading imei... Imei: 358361004179697 Waiting for TP confirmation....................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Done! |
12-06-2007, 16:36 | #5 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @n80 Code: Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 3, FBUS Code count: 1 Block 1: Lock 1: CLOSED -> Lock Data: 23420F Block 2: Lock 1: CLOSED -> Lock Data: 23420F Block 3: Lock 1: CLOSED -> Lock Data: 23594F Block 4: Lock 1: CLOSED -> Lock Data: 23594F Reading phone...Type: RM-92, Ver: 05wk33v33.1 Reading imei... Imei: 358361004516781 Waiting for TP confirmation..................................................................................................................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Done! |
12-08-2007, 14:53 | #6 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @E65 RM-208 Code: Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 5050300014981890 Provider: Vodafone;Australia Key Code count: 2, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50503F Block 2: Lock 1: CLOSED -> Lock Data: 50503F Reading phone...Type: RM-208, Ver: 1.0615.25 Reading imei... Imei: 353263010949359 Waiting for TP confirmation...........................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 5050300014981890 Provider: Vodafone;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Done! |
12-10-2007, 08:09 | #8 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @n73 rm-133 Code: Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Block 2: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-133, Ver: 05wk47v46.3 Reading imei... Imei: 353640014406066 Waiting for TP confirmation....................................................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Done! |
Rm-89 E61 In 5 Minutes | chiragp | J.A.F. V-SPEC | 1 | 01-13-2014 17:35 |
W200 Unlocking In 5 Minutes | maplegsm | DreamBox | 2 | 04-26-2008 08:53 |
again again n73 unlocked in 5 minutes no more | dasuza | BB5 Box by D.K. | 1 | 11-19-2007 12:48 |
3250 Secuccessfully Unlocked in 5 Minutes | .::Gsm Killer::. | MT-BOX | 4 | 08-31-2007 11:01 |
