who can show the proper solution C:\Program Files\ODEON\JAF\ProgData\RM-198_353085020040808_05.03_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 5050100058056920 Provider: Telstra Mobile Comms;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50501F Block 2: Lock 1: CLOSED -> Lock Data: 50501F Reading phone...Type: RM-198, Ver: 05.03 Reading imei... Imei: 353085020040808 Reading HW ID...1402 Found general data... Waiting for TP confirmation................... |
better solution is that please connect tp properly |
tp is connect properly ,have do scratch clean tp also.Is new never unlock any phone yet ,could this be error box cause no light coming from box even power light is not coming.have do update p-key many times also same error. In box rj45 pin which one is data and clk (tp) |
the pin with a button is DATA and the thinner pin is CLK and if the power light of vspec is not glowing how you posted the logs it will not detect phone if vspec is not powering |
this is the problem .Cable ,box or what is wrong.The box is no light connect cable power on the phone go local mode ok when show tp confirmation ,i start connect the tp just nothing going ............................all the way failed |
did you connect the cable properly of vspec with jaf box 1 side it has 10 pin it should connect to vspec and other side it has 8 pin that should connect to jaf box |
