![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2005 Age: 62
Member: 206710 Status: Offline Thanks Meter: 13 | ![]() today I received 6280 with pin #17 damaged (somebody tried with no luck), but job done by JAF Plus!!! ![]() here below is the log JAF version 1.98.59 Detected PKEY: 9000**** Card life counter: 88.37% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112 JAF DCT4/BB5 LOADERS DIR: C:\Programmi\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Programmi\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Programmi\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Programmi\ODEON\JAF\Flash3\ USB Cable Driver version: 6.83.9.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... Failed! Aborting! IMEI FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.43 30-03-07 RM-78 (c) Nokia HW version: 1008 PCI version: RFIC version: 17211721 DSP version: pb05w46v49 LCD version: SHARP PPM version: V 06.43 30-03-07 RM-78 (c) Nokia C Retu version: 32 Tahvo version: 52 Content Pack version: Content: 3_it2 V 06.43 30-03-07 RM-78 (c) Nokia Production serial number: SIG899256 Product code: 0541918 Module code: Basic production code: 0540642 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35322********** IMEI spare to net: 3A 35 22 ** ** ** ** ** IMEI SV to net: ** ** ** ** ** ** 17 18 F8 LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2229900093172790 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 22299F Searching for saved ini... Checking for file C:\Programmi\ODEON\JAF\JAF_RM-78.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0541918 Searching for JAF saved location of ini... Checking path: C:\Programmi\Nokia\Phoenix\Products\RM-78\ Searching for default location of ini... Checking path: \Products\RM-78\ Searching for JAF saved location of ini... Checking path: C:\Programmi\Nokia\Phoenix\Products\RM-78\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... C:\Programmi\ODEON\JAF\ProgData\RM-78_35322**********_06.43_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2229900093172790 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 22299F Reading phone...Type: RM-78, Ver: 06.43 Reading imei... Imei: 35322********** Reading HW ID...1008 Found general data... Waiting for TP confirmation...................................... ..........Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2229900093172790 Provider: Unknown provider Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 22299F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Programmi\ODEON\JAF\ProgData\RM-78_35322**********_06.43_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2229900093172790 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 22299F Reading phone...Type: RM-78, Ver: 06.43 Reading imei... Imei: 35322********** Reading HW ID...1008 Found general data... Waiting for TP confirmation...................................... ...................Sending code... Sending code... Communication lost... repower the phone and try again! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2229900093172790 Provider: Unknown provider Key Code count: 1, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 22299F Reading phone...Type: RM-78, Ver: 06.43 Reading imei... Imei: 35322********** Reading HW ID...1008 Found general data... Waiting for TP confirmation...................................... ...................................Sending code... Communication lost... repower the phone and try again! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2229900093172790 Provider: Unknown provider Key Code count: 1, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 22299F Reading phone...Type: RM-78, Ver: 06.43 Reading imei... Imei: 35322********** Reading HW ID...1008 Found general data... Waiting for TP confirmation...................................... ....................Sending code... Unlock OK! Reading simlock data... Error reading simlock data... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.43 30-03-07 RM-78 (c) Nokia HW version: 1008 PCI version: RFIC version: 17211721 DSP version: pb05w46v49 LCD version: SHARP PPM version: V 06.43 30-03-07 RM-78 (c) Nokia C Retu version: 32 Tahvo version: 52 Content Pack version: Content: 3_it2 V 06.43 30-03-07 RM-78 (c) Nokia Production serial number: SIG899256 Product code: 0541918 Module code: Basic production code: 0540642 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35322********** IMEI spare to net: 3A 35 22 ** ** ** ** ** IMEI SV to net: ** ** ** ** ** ** 17 18 F8 LOCK STATUS: CONFIG KEY: 8000000000000006 PROVIDER KEY: 2229900093172790 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN |
Pin find ok but not working china miracle. | Qaisar Mahmood | Infinity-Box | 3 | 11-14-2008 20:54 |
N95 when unlocking but testpoint failed.. but ok i have the pm what next ? | DjSwift | MT-BOX | 1 | 04-08-2008 21:46 |
Why JAF BB5 is 7 pin but MT-Box Nokia is 10 pin? | steffi2 | MT-BOX | 4 | 08-08-2007 18:09 |
BOX Damaged & Smart Card OK | DZStorm | NSPRO | 4 | 03-27-2007 19:20 |
LG cable i made 26 pins but i need the other pin outs | jorus | LG | 0 | 10-14-2003 09:43 |
