12-02-2007, 01:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: USULUTAN, EL SALVADOR. Age: 47
Member: 545374 Status: Offline Thanks Meter: 34 | 5300b dead when unlocking br juvenile |
12-02-2007, 09:28 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | please post here a flashing log. because the phones cannot die from unlocking. when you got error unlocking, the only bad thing that can happend, i mean the worst thing that can happend is that the counter increase by 1. the phone cannot die. try to flash it again with fw 5.02 and post here flashing log br |
12-02-2007, 19:59 | #3 (permalink) |
Member: 545374 Status: Offline Thanks Meter: 34 | ok, i already flashed 2 more 5300b rm147 but i see that after flash they are rm146, so the one that is dead does not connect with the jaf in fbus, not even in usb mode, so maybe is dead, so this is the log of the last one, i will try to unlock it now. Reading... MCU SW version: V 04.51 11-01-07 RM-147 (c) Nokia. HW version: 3003 PCI version: RFIC version: 17211721 DSP version: pb06w14v33 PPM version: V 04.51 11-01-07 RM-146 (c) Nokia. NTM BT MCM version: 06cc-P8.0 Retu version: 32 Tahvo version: 53 Content Pack version: Content: n V 04.51 11-01-07 RM-146 (c) Nokia. Production serial number: RNA982315 Product code: 0515264 Module code: 0203052 Basic production code: 0530539 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: ************** IMEI spare to net: 3A 45 65 07 11 38 49 00 IMEI SV to net: 33 45 65 07 11 38 49 00 F5 LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310300 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-147.ini FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Setting local mode... Reading product code... Product Code: 0515264 FILES SET FOR FLASHING: MCU Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.mcusw PPM Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.ppm_ntm CNT Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.image_n_tmobusa_v2 APE Variant file: NONE Backing up CRT data... Setting FLASH MODE Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... VARIANT CRT empty, skip save... Reading CMT CCC certificate... Reading CMT HWC certificate... Saved to C:\Archivos de programa\ODEON\JAF\ProgData\***************_CRT_ba ckup_1243212.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Archivos de programa\ODEON\JAF\ProgData\****************_CRT_b ackup_1243212.pm Done! Backup LCK OK! Reading SW version...04.51 Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 18D00010C8216056F0DBF015B089C5CC5B33BD80 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Archivos de programa\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22FE00EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Archivos de programa\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready Operation took 0 minutes 7 seconds... Sending CRT data... Erasing... Operation took 1 minutes 58 seconds... Writing... Stage 1 Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC Sending CMT PUB KEYS... Sending CMT HASH for UPDAPP Sending CMT HASH for DSP0 Sending CMT HASH for MCUSW Sending CMT HASH for PMM_CONF Sending CMT HASH for SBIF_CONF Operation took 2 minutes 14 seconds... Reseting phone... PPM: C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.ppm_ntm Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 18D00010C8216056F0DBF015B089C5CC5B33BD80 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Archivos de programa\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22FE00EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Archivos de programa\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready Operation took 0 minutes 6 seconds... Erasing... Operation took 0 minutes 31 seconds... Writing... Stage 1 Operation took 0 minutes 36 seconds... Reseting phone... CNT: C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.image_n_tmobusa_v2 Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 18D00010C8216056F0DBF015B089C5CC5B33BD80 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Archivos de programa\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22FE00EC -> ST CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Archivos de programa\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.16.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready Operation took 0 minutes 6 seconds... Erasing... Operation took 1 minutes 15 seconds... Writing... Stage 1 Operation took 0 minutes 30 seconds... Reseting phone... Done! Total time: 7 Minutes, 25 Seconds DCT4/BB5 counter: 51 After flash processing... Waiting for phone to boot... Reading... Phone type: RM-146, Software version: 05.02 IMEI: 354567011839404 APE Ver: (null) Variant Ver: (null) Product Code: 0515264 Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 1 seconds... Done! Done! Done! u know what?, Andres u better first tell me if i can unlock it now or i better don't touch this set, i am afraid now to kill it and not be able to revive it. br juvenile |
12-02-2007, 22:04 | #4 (permalink) | |
Member: 545374 Status: Offline Thanks Meter: 34 | Quote:
PRESS POWER ON THE PHONE NOW!!! Searching for phone...Detected P-KEY: ******* P-key nokia module version 01.00 Init usb communication... Found Starting DEAD USB phone flashing... Using 06.02.002 Elf2flash 02.33.000 RAW loader... Patching RAW boot step1... Patching RAW boot step3... Sending RAW Loader... ...................Loader Sent! Stage 2 starting.......................................... ..................Loader Sent! Stage 3 starting..................Phone prepared OK! Waiting for the phone to boot... Searching phone...Found! Status byte: 04 Phone is in flash mode... CMT blocks: 1398, APE blocks: 0 Erasing cmt... Send CMT CFG... Processing C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.mcusw... Erasing cmt zone 00000000 - 000006BF ... Erasing cmt zone 000006C0 - 0001FFFF ... Erasing cmt zone 00020000 - 0007FFFF ... Erasing cmt zone 00080000 - 000DFFFF ... Erasing cmt zone 00100000 - 001FFFFF ... Erasing cmt zone 00200000 - 0031FFFF ... Erasing cmt zone 00320000 - 0105FFFF ... Erasing cmt zone 01060000 - 01067FFF ... Erasing cmt zone 01068000 - 0107FFFF ... Processing C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.ppm_ntm... Erasing cmt zone 01080000 - 015FFFFF ... Processing C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.image_n_tmobusa_v2... Erasing cmt zone 01600000 - 01FDFFFF ... Writing cmt... Processing C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.mcusw... Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... Sending CMT HASH for UPDAPP Sending CMT HASH for DSP0 Sending CMT HASH for MCUSW Sending CMT HASH for PMM_CONF Sending CMT HASH for SBIF_CONF Processing C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.ppm_ntm... Processing C:\Archivos de programa\Nokia\Phoenix\Products\RM-147\rm146__05.02.image_n_tmobusa_v2... Rebooting... Restarting CMT... Pooling phone... MCUSW: (null) APESW: (null) VariantSW: (null) Prodcode: Setting test mode... Failed! Aborting! DCT4/BB5 counter: 53 Done! tell what to do please br juvenile | |
12-04-2007, 00:23 | #5 (permalink) |
Member: 545374 Status: Offline Thanks Meter: 34 | Andres or Raskal i need your help hello sir, i just tried to unlock another 5300b and it is now dead, both are from movistar, if i send to you the prl_backup, can u check why these sets get killed with ur box, i mean now we have the problem that the sets are killed, and i have unlocked another 5300 like this ones and they always get killed, i hope u can help me with this and help other jaf plus users. br juvenile |
5300b dead after unlock ! | jawad8305 | Nokia Base Band 5 ( BB-5 ) | 3 | 08-31-2008 14:10 |
LG 8330 dead when unlocking by patching =help | bentys2000 | Cruiser Suite | 0 | 07-19-2006 18:37 |
U8120 dead when unlocking | khoavtran | FuriouS II | 11 | 07-05-2005 20:14 |
pls need help .gx15 dead when unlocking with ferious | ::.::SOUFIZ GSM::.:: | Sharp | 6 | 01-16-2005 20:40 |
E800 dead when unlocking | unlockclips.com | SYSOL Platform | 8 | 08-20-2004 02:19 |
