12-07-2007, 13:11 | #1 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 141927 Status: Offline Thanks Meter: 27 | N91 unlock error -------------------------------------------------------------------------------- please help jaf team JAF version 1.98.42 Detected PKEY: 9000428F Card life counter: 98.88% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V w33_06w24v2 24-07-06 RM-43 (c) Nokia. HW version: 0600 PCI version: RFIC version: 150a160f DSP version: nemo_w_05wk32v33 Retu version: 32 Tahvo version: 52 Production serial number: SFF273903 Product code: 0535111 Module code: Basic production code: 0525426 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358391001053199 IMEI spare to net: 3A 85 93 01 10 50 13 09 IMEI SV to net: 33 85 93 01 10 50 13 09 F0 LOCK STATUS: CONFIG KEY: 5050600042465540 Provider: Hutchinson 3G;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50506F Block 2: Lock 1: CLOSED -> Lock Data: 50599F Block 3: Lock 1: CLOSED -> Lock Data: 50506F Block 4: Lock 1: CLOSED -> Lock Data: 50599F Block 5: Lock 1: CLOSED -> Lock Data: 00101F Block 6: Lock 1: CLOSED -> Lock Data: 00101F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-43.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0535111 INI file 0535111.ini is missing. Continue searching for second ini type... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 5050600042465540 Provider: Hutchinson 3G;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50506F Block 2: Lock 1: CLOSED -> Lock Data: 50599F Block 3: Lock 1: CLOSED -> Lock Data: 50506F Block 4: Lock 1: CLOSED -> Lock Data: 50599F Block 5: Lock 1: CLOSED -> Lock Data: 00101F Block 6: Lock 1: CLOSED -> Lock Data: 00101F Reading phone...Type: RM-43, Ver: w33_06w24v2 Reading imei... Imei: 358391001053199 Version Not supported! |
12-07-2007, 18:14 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | as you can see in supported phones list, N91 is not supported because we dont have an locked phone for the moment. maybe you will contact me and sell us one. br |
n95-3 ,e61 , n91 no unlock error | luis campos | BB5KING for (BB5BOX) | 0 | 11-19-2008 23:16 |
N91 Disk Error | rameshbhaskar | Nokia Base Band 5 ( BB-5 ) | 2 | 11-18-2006 16:02 |
n91 flashing error | Poor_yorick | Universalbox | 3 | 05-05-2006 15:12 |
