Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > J.A.F. Plus
Old 11-04-2008, 03:56   #1 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
problem in connecting 3120c
i have 3120c-1c rm-364 with restart problem. so i want to format the c drive . i m trying with usb connection. so do we need additional software like pc suite and additional driver to connect it.
Old 11-10-2008, 11:52   #2 (permalink)
Member: 463150
Thanks Meter: 91
problem solved ============
roshantelecom&s helped me with the exact procedure to connect the phone with usb.... here is the log with jaf.....
Detected PKEY: ----------------
Card life counter: 96.56%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-364\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\
No ini files found...
Scanning ini files...
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.mcusw
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.ppm_m1
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16_ISM_003.image_m1_eg_graphite
Languages in ppm: English,French,Arabic
Backing up CRT...
Detected P-KEY: 9001C6BB
Init usb communication...
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ...................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 167, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.mcusw...
Erasing cmt zone 00000000 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 01480000 - 015FFFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 0147FFFF ... Erase result: 0000
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.ppm_m1...
Erasing cmt zone 01600000 - 01CBFFFF ... Erase result: 0000
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16_ISM_003.image_m1_eg_graphite...
Erasing cmt zone 01FC0000 - 03F9FFFF ... Erase result: 0000
Erasing cmt zone 01CC0000 - 01FBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: V 07.16
27-05-08
RM-364
(c) Nokia
APESW: (null)
VariantSW: (null)
Prodcode: 0559107
DCT4/BB5 counter: 20
Done!
THANKS TO roshantelecom&s
and other forum members
The Following 2 Users Say Thank You to vishal123123 For This Useful Post:
need to know the correct e207 pinouts as problems in connecting! ReyTech Infinity-Box 3 05-29-2008 15:41
problem in connecting ust pro with computer masterspargo UST Pro II 1 12-06-2007 10:30
6288 problem in connectivity waleedy Nokia Base Band 5 ( BB-5 ) 3 02-15-2007 03:31
Problem in Connecting Philips 355 Aamir_Zia Multi-Box 15 08-11-2005 17:12
Page generated in 0.14713 seconds with 9 queries
