08-09-2009, 00:11 | #1 (permalink) |
Insane Poster Join Date: Oct 2004 Age: 56
Member: 84639 Status: Offline Thanks Meter: 2 | 5800d RM-356, died... Help Me!!! I have an unlocked phone that is dead (about a month ago with the cyclone and I did not make backups), it was not recognized by any box in FBUS mode. I managed to revive it and now on the screen appears in Local Mode with FBus cable. I tried to turn it on with the battery but the phone only vibrates and anything else. For more details it is attached log of my JAF box. What I can recognize is the CONFIG KEY 00000000000. To repair the mobile I have the following boxes: JAF, UFS (which have HWK), and Cyclone. JAF version 1.98.63 Detected PKEY: 90XXXXXX Card life counter: 92.88% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia HW version: 1101 PCI version: RFIC version: DSP version: APE SW Core version: V 21.0.025 APE Variant version: V 21.0.025V 21.0.025 APE Test version: eno_version Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Content Pack version: v 20.0.010_008_xxx_U01 21-01-09 vanilla RM356 Production serial number: CCI645017 Product code: 0576050 Module code: Basic production code: 0558954 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 354216037XXXXX IMEI spare to net: 3A 45 12 06 73 13 28 02 IMEI SV to net: 33 45 12 06 73 13 28 42 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140100000000000 Provider: Vodafone / Airtel Movil;Spain Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-356.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0576050 Searching for JAF saved location of ini... Waiting for a prompt answer. Best Regards |
08-15-2009, 18:10 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | Quote:
flash with jaf then post results above log shows everything fine | |
09-06-2009, 19:48 | #4 (permalink) |
Insane Poster Join Date: Sep 2007 Location: india Age: 39
Member: 582476 Status: Offline Thanks Meter: 8 | CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140100000000000 Provider: Vodafone / Airtel Movil;Spain Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN your sp area is ok just flash the phone |
02-21-2010, 06:52 | #5 (permalink) |
Junior Member Join Date: Feb 2010 Location: Venezuela
Member: 1237338 Status: Offline Thanks Meter: 3 | hey pal hi friend, can you post your ccc data and hwc data or your full rpl??? i have the same phone model (0576050) with the same problem and i need this information to repair my phone with mxkey and then i will post the results to help you Thanks in advance |
5800d RM-356, died... Help Me!!! | Celumania | Cyclonebox | 2 | 08-09-2009 05:49 |
5800d RM-356, died... Help Me!!! | Celumania | Nokia Base Band 5 ( BB-5 ) | 3 | 08-09-2009 01:46 |
5800d rm-356 please help need flash file | : ronfreek : | Nokia Hardware & Hardware Repair | 0 | 02-01-2009 18:09 |
