Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > No more Support JAF Products. > J.A.F. Plus
Old 05-29-2009, 13:26   #1 (permalink)
faisal4friend's Avatar
Member: 262523
Sonork: 100.1611482
Thanks Meter: 288
Nokia 1600b Contact Service-5
hello
I get Nokia 1600b Made in MAXICO. when power it on without sim card, it works fine.
But I put the Sim Card, it says Contact Service-5.
First time m facing this problem.
I faced many contact service in Nokia 1600. but its strange. in 1600 usually Contact service appear in the in Blue LCD and in this Blue Light have written Small Contact Service.
But in this fon. Contact service-5 shows just like when we power on the phone without sim card and phone says Insert Sim Card in Large Words.
here is the log took from J.A.F.
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 6.00
10-24-06
RH-65
© NMP
HW version: 0529
PCI version:
UEM version: 1328
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: SDI:LD184v89
PPM version: V 6.00
10-24-06
RH-65
© NMP
UB
ADSP SW version: V 6.00\n10-24-06\nRH-65\n© NMP\nub_lta
Production serial number: RCR059171
Product code: 0532765
Module code: 0202592
Basic production code: 0536232
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 010783000552280
IMEI spare to net: 0A 01 87 03 00 55 22 08
IMEI SV to net: 03 01 87 03 00 55 22 38 F1
Master Code: 2043205074
Phone type: RH-65, Software version: 6.00, Language Pack: UB
User code: ÿ#
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-65.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0532765
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-65\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-65\
Searching for JAF saved location of ini...
No ini files found...
Done!
If any friend have any idea about it plz share as soon as possible.
Thanx in Advance.
The Following User Says Thank You to faisal4friend For This Useful Post:
Old 06-01-2009, 11:50   #2 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
bro fully erase and flash with latest ver of rh-64 , write good pm then unlock and ui setting . hope it ll help you .
Nokia 1600b Contact Service-5 Adil Mobiles Nokia Hardware & Hardware Repair 16 11-03-2013 07:11
Nokia 1600B - Contact service 5 pls. help... Joda Nokia Hardware & Hardware Repair 1 08-29-2009 18:59
nokia 1600b contact service 5 lacasapc J.A.F. By Jafsupport.com 2 06-02-2008 13:20
Page generated in 0.12207 seconds with 9 queries
