08-29-2008, 03:32 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Portugal Age: 41
Member: 241933 Status: Offline Thanks Meter: 77 | i cant unlock any bb5 |
08-29-2008, 09:26 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: portugal
Member: 37485 Status: Offline Thanks Meter: 77 | hi That also happen to me, and i try this: change Connectivity Cable Driver to a lower version 6.83.... update th Pkey and change the TP cable to 2 nedlles and 2 cables used in PS2 chip. Problem solved. Sometimes is necessary to flash again phone to a latest soft even when it as. It solves any problem even in N80. Hope it helps. |
The Following User Says Thank You to humb11luis For This Useful Post: |
08-29-2008, 14:51 | #3 (permalink) | |
Member: 241933 Status: Offline Thanks Meter: 77 | Ok , i will try and post here the results. Thanks Quote:
08-29-2008, 20:33 | #4 (permalink) |
Member: 241933 Status: Offline Thanks Meter: 77 | i search for nokia cable drivers 6.83 but i cant find , i already install pc suite 683 but he dont install the cable drivers??? where i can get this drivers??? |
08-29-2008, 22:52 | #5 (permalink) | |
Member: 241933 Status: Offline Thanks Meter: 77 | Quote:
I use jaf 1.98.57 and i update pkey, i flash the phone to version 5.00, and nothing..... jaf log: Backup simlock data first... Setting local mode... Reading IMEI... C:\Programas\ODEON\JAF\ProgData\RM-174_356407018379104_05.00_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2680300000000000 Provider: Optimus;Portugal Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 26803F Reading phone...Type: RM-174, Ver: 05.00 Reading imei... Imei: 356407018379104 Reading HW ID...2501 Found general data... Waiting for TP confirmation...................................... ........Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. | |
08-29-2008, 23:11 | #6 (permalink) | |
ok , after this i try 5 more times and unlock the phone. i put first the data (ad8) and next the clk needle and he unlock. i will try with on N95 and check if jaf is working 100% ok. Thanks for the tips, i hope this help someone with the same problem. | |
08-31-2008, 23:33 | #10 (permalink) |
Member: 241933 Status: Offline Thanks Meter: 77 | ok, i already try the easy TP http://forum.gsmhosting.com/vbb/show...ight=sagmaster and no results. And i am using the smallest needles like nurses use to suck the blood |
08-31-2008, 23:45 | #11 (permalink) |
Member: 241933 Status: Offline Thanks Meter: 77 | always same result LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2680100000000000 Provider: Vodafone / Yorn;Portugal Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 26801F Block 2: Lock 1: CLOSED -> Lock Data: 26801F Reading phone...Type: RM-133, Ver: 05wk47v51.4 Reading imei... Imei: 359568015421293 Reading HW ID...7100 Found general data... Waiting for TP confirmation...............................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again |
09-03-2008, 00:58 | #12 (permalink) | |
Member: 241933 Status: Offline Thanks Meter: 77 | TP Cable modified by me ok , here is me again , after try many times and past hours trying unlock one N73 i solve to do some hardware tests and changings, and i found some curios values.... and i made one TP cable modified Till now i only unlock this n73 but i will try do more bb5 and post here my results with this cable. I unlock N73 on first try with this : -Windows XP -Jaf software 1.98.57 -(i dont think its necessery but i install network frame v1.1) -Nokia connectivity cable drivers v.6.83.9.0 - And the cable modified by me (see the picture) Instructions: Connect all the wires to ur phone (Vph,Gnd,BSi,phone connector, and press unlock power the phone and wait for "waiting testpoint......" , this part its very important connect first the "CLK" needle and after that connect the "data" needle. And .........UNLOCK OK If anybody will try doing this please post here ur results Jaf log: Quote:
The Following User Says Thank You to badwily For This Useful Post: |
09-03-2008, 18:31 | #14 (permalink) | |
Member: 241933 Status: Offline Thanks Meter: 77 | About that picture i attached on the up post had some incorrect draw resistor . See here the new Schematic Corrected Quote:
09-03-2008, 19:18 | #15 (permalink) | |
Junior Member Join Date: Jul 2007
Member: 553506 Status: Offline Thanks Meter: 8 | Quote:
hi friend now available pc suit v 7.0.8.2 pl update this latest version try and post result thanks | |
::cant unlock any bb5 phones:: ANSWERED | GPG_SUPPORT | Universalbox | 10 | 03-29-2010 10:29 |
i cant unlock any bb5 ? | SAN INFOTECH | Universalbox | 2 | 02-16-2010 14:57 |
please help me since i cant unlock any bb5 | sesime | JAF No Tp Unlocker by Cinek | 0 | 12-22-2008 14:33 |
cant unlock any bb5 nokia | phone connect | MT-BOX | 1 | 04-25-2008 23:46 |
cant flash any BB5 with mt-box | Softway | MT-BOX | 5 | 06-12-2007 16:53 |
