Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
Member: 200475 Status: Offline Thanks Meter: 37 | problem unlocking 5300 sw version 5.00 I have a 5300 with s/w 5.00. try to unlock. See below log. However, it comes up error unlocking. I found the "Key Code count: 3 " , is that means the phone is locked up because customer tried too many times key in the code ? Any solution ? tks SS __________________________________________ Detected P-KEY: 90000A12 P-key nokia module version 01.00 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.00 27-04-07 RM-146 (c) Nokia. HW version: 2007 PCI version: RFIC version: 17211721 DSP version: pb06w14v51 PPM version: V 05.00 27-04-07 RM-146 (c) Nokia. T BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: opv_boost V 05.00 27-04-07 RM-146 (c) Nokia. Production serial number: DAJ992544 Product code: 0556890 Module code: 0203051 Basic production code: 0530536 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358059017211941 IMEI spare to net: 3A 85 50 09 71 12 91 04 IMEI SV to net: 33 85 50 09 71 12 91 04 F8 LOCK STATUS: CONFIG KEY: 5050200000000000 Provider: Singtel Optus-Cable + Wireless Optus;Australia Key Code count: 3, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50502F Block 2: Lock 1: CLOSED -> Lock Data: 50502F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-146.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0556890 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-146\rm146__05.00.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-146\rm146__05.00.ppm_q CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-146\rm146__05.00.image_q APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 5050200000000000 Provider: Singtel Optus-Cable + Wireless Optus;Australia Key Code count: 3, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50502F Block 2: Lock 1: CLOSED -> Lock Data: 50502F Reading phone...Type: RM-146, Ver: 05.00 Reading imei... Imei: 358059017211941 Waiting for TP confirmation.................Sending code... Waiting for TP confirmation.....Sending code... Error unlocking! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 5050200000000000 Provider: Singtel Optus-Cable + Wireless Optus;Australia Key Code count: 3, FBUS Code count: 2 Block 1: Lock 1: CLOSED -> Lock Data: 50502F Block 2: Lock 1: CLOSED -> Lock Data: 50502F Reading phone...Type: RM-146, Ver: 05.00 Reading imei... Imei: 358059017211941 Waiting for TP confirmation....................Sending code... Waiting for TP confirmation... |
![]() | #3 (permalink) | |
Member: 200475 Status: Offline Thanks Meter: 37 | Quote:
I went to the support site but can't find MCU Firmware version RM-146_DP20_2.00__sw-05.02.exe If that's RM-146_DP20_2.00, the sw is 03.92, also, there is no 05.02 version only 05.00 or 05.50 ava. Also, according to your update, 05.00 is one of the supported version, so we don't have to flash the firmware, right ? About that key count is "3", I did some search yesterday over the forum. few people report the similar situation that error unlocking is coming up when processing TP unlocking because of this key count is "3" and has to do sth about the RPL, can you clarify ? thank you again for yr help. SS Pls advise which one to go ? Thank you. | |
![]() | #4 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | Key Code count: 3, FBUS Code count: 0 no need to buy ask/rpl services. you still have FBUS count to 0. jaf sw automatickly search if you have any of the counters not blocked, and make unlock. br |
![]() | #5 (permalink) | |
Also, I went to the support site but can't find MCU Firmware version RM-146_DP20_2.00__sw-05.02.exe If that's RM-146_DP20_2.00, the sw is 03.92, also, there is no 05.02 version only 05.00 or 05.50 ava. Also, according to your update, 05.00 is one of the supported version, so we don't have to flash the firmware, right ? thank you again for yr help. SS Pls advise which one to go ? Thank you. | |
![]() | #6 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: USULUTAN, EL SALVADOR. Age: 46
Member: 545374 Status: Offline Thanks Meter: 34 | ok, thats the flash MCU Firmware version RM-146_DP20_2.00__sw-05.02.exe and yes, the sw version is 5.02 you have to look at the version from t-mobile black, the 3.92 is from telcel, thats not the correct one. br juvenile |
![]() | #10 (permalink) | |
what about 6233 & 6234, I have 2 phones both 5.10. I unlock the same way as 6288 but fail all the time, any suggestion ? also, the phone is not easy to power on, has to reattach the GND couple of times before can power up ! pls advice. tks SS | |
![]() | #13 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2003
Member: 30661 Status: Offline Thanks Meter: 0 | Im having the same problem I have tried one by one flashing each of the different versions available in support to the phone then trying to unlock and I keep getting the same thing, unlock failed! CONFIG KEY: 2341000000000000 Provider: 02 - Cellnet;United Kingdom Key Code count: 3, FBUS Code count: 8 Block 1: Lock 1: CLOSED -> Lock Data: 23410F Reading phone...Type: RM-146, Ver: 04.70 Reading imei... Imei: 35*********** Waiting for TP confirmation......Sending code... Waiting for TP confirmation....Sending code... Error unlocking I have tried several different cables, all the flash files I could find and 2 different Jaf Plus boxes... Can someone please help? |
![]() | #14 (permalink) |
Member: 30661 Status: Offline Thanks Meter: 0 | Tried the same thing on a 6300, which is the first one supported on the 6300 supported list. It does the same thing, I have confirmed with my reseller that everything is activated for BB5 but I still cant unlock any phones? |
Problem unlocking 6300 version 5.00...also 5.52 | Unlocker AL | J.A.F. V-SPEC | 20 | 06-25-2008 19:23 |
Nokia 7373 version 5.00 unlock? | mobile_2003 | MT-BOX | 3 | 02-29-2008 14:16 |
5200 SW Version 5.00 Unlock Solution !!! | mughalG | BB5BOX | 58 | 12-20-2007 15:48 |
Problem Unlocking 5200 Version 5.00 Black | Mansoor | UID - Box | 7 | 11-02-2007 05:05 |
