Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 12-09-2009, 18:18   #1 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
China 6225 IMEI write problem
Hello all..
i have china 6225 cpu phone which shows 000000000000 imei when i write new its show two imei and change ok but when i insert battery and check it show again 000000000000000000000 i format the write imei but same problem any solution pls provide need urgent..
thnx in advanced
W.B.R
Old 12-09-2009, 19:29   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
if u have infinity then u can easly solv this
Old 12-09-2009, 20:43   #3 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
can you tel how i have infinity AND multibox too i need soltution
Old 12-10-2009, 09:41   #4 (permalink)
Member: 637177
Sonork: 100.103098
Thanks Meter: 8,663
when change IMEI. you can not format or flash again. if flash or format phone imei will back to before
Old 12-10-2009, 17:11   #5 (permalink)
Member: 295367
i have same problem...........
not doing flash or format after writing imei but when i press *#06# with battery it shows 00000000000
China Mobile IMEI write Which Method is Good META/AT ?????? srinibas SpiderMan 1 12-07-2009 09:31
SAMSUMG D880 Imei Write Problem maplegsm NSPRO 2 12-07-2008 16:49
N95 bluetooth FM--E559_JJF3F8.01.1_26S-imei write problem gsmcodeman Infinity-Box 1 01-18-2008 14:57
6230 imei write problem marekom Nokia Hardware & Hardware Repair 0 12-31-2005 14:02
E700 IMEI Writing problem looper SYSOL Platform 2 05-25-2004 14:08
Page generated in 0.13438 seconds with 9 queries
