::Here How To Work With Spider-Man Box :: Here Only You Can Find How To Use Spider-Man Box http://www.i-phoneteam.com/matrix/SPider%20man.JPG 1-The Connect button which use for connect box with program If connection Is Good this button will be Disconnect 2-Select Comport which u can use 3-Select Baundrate For Comport 4-Used For Make Conaction With Phone ((Boot The Phone)) 5-Used For Make Order To write selected Flash Files on Nor Flash Or Nand Flash 6-Used For Make Order To Read Flash Files Form Phone And Request for where u want to save backup flash files 7- Used For Make Format Opration and if u check to Manual Format Default this option is required to Make Manual Set For Foramt Area http://www.i-phoneteam.com/matrix/spider%202.bmp 8-Used For Unlock Phones ((open all network locks )) 9-Used For Find Pinout For Phone and give us Correct Tx And RX Pins (( We Can choose From 2 Options 1St, 1 Cpu Phones - 2Nd, 2Cpu Phones )) 10- We Can Used This Option to Defind Pinouts and Save Our Correct pinouts Searching 11-This Opation allowed us To Convert Flash Files which Had Bin Extension To Bif Extension 12-Used For Abort Any Working Opartion 13-Used TO Know Any New Updates In Support Area 14-This Bar allowed us To Change between Phone Cpu which We Have Like MTK And SPreadtrum ....... 15- here We Can Open Nor Flash which we Want To Flah it to phone 16- here we also can choose where we want to save reading flash files 17- Same as last oprations ((15-16)) But Here For Nor Flah Area 18- Used For Rebuild Iemi for Phone 19- Used For Make Full Factory Defaults 20- The Area For Read all Info About SW and Flash File Details Hope This Info Help U TO Work With This Great Tool |
Spiderman Read&Flash connect box to computer .connect phone to box and cable YOU Must choose MTK CPU.click”Search Phone”.when found cable pinout 1. Read flash * click”Save” Choose save file folder and save name * click"Read” after press” power on”button in the phone Bootloader phone Reading........ http://www.i-phoneteam.com/matrix/4.JPG 2. Flash phone. * Click”Open” choose flash the phone flash file * Click”Flash” after press” power on”button in the phone Bootloader phone http://www.i-phoneteam.com/matrix/6.JPG NOW Flash complete BR, SiLverGSM |
great moved man... keep it up... |
yes fırst pın outo good work good fınd hehe spıderman best box |
thks for explain............................ |
Great .. very nice mr's GsmJoman Tc |
Great Mr Silver Good Luck B'R Minihack |
great work ...:) m.r :silver |
thank u mr. silver very good |
how i can format spreadtrum cpu very good sir but how i can format & read ,write flash for spreadtrum cpu ..::RICKY RAYYA::.. |
very nice mr//SiLverGSM MR / KEMO |
Great work from my dear brother Best Regards... Your Borther KimoAlex |
We working for this now just few steps and it will be ready Br, SiLverGSM |
THE BEST OF ALL very nice mr//SiLverGSM |
and what r u doing for infeneon cpu, pls give fast update.... now badly need the support of speadtrum and infeneon cpu to unlock , flash read/ write .................... |
