Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 05-16-2008, 00:17   #1 (permalink)
Member: 68778
Thanks Meter: 5
How to use SpiderMan for Sagem, LG, SE, Motorola, Pantech, Fly, O2, ZTE etc.
How to use SpiderMan for Sagem, LG, SE, Motorola, Pantech, Fly, O2, ZTE etc.??
Old 05-16-2008, 04:06   #2 (permalink)
kabirhossain's Avatar
Member: 271880
Sonork: 100.1578866
Thanks Meter: 1,289
SpiderMan for only china clone mobile repiaring not branded mobile,
you want use others model rx/tx with SpiderMan com port...
Old 05-16-2008, 05:14   #3 (permalink)
Member: 211597
Thanks Meter: 5
Poor Spiderman no brand....... only copy brAN, MOVE U UP ..........thanks
Old 05-16-2008, 05:23   #4 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 219
if your phone's cpu is supported by spiderman box you can repair it by formatt, unlock , flash (mtk. spredtrum )
otherwise as a pinout finder you can use with any other software as selecting com port
spiderman is fastest pinout serching box
Old 05-16-2008, 05:44   #5 (permalink)
Member: 42604
Thanks Meter: 187
You can used Spiderman to connect to other phone regardless of brand or models (max. 24 pins) as long as you have the correct pinout of that phone then click CABLE DEFINE (NOT the SEARCH PHONE!) then manually enter the correct pinout of the phone (RX/TX/GND).
Old 11-08-2008, 04:55   #6 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
i use my spiderman with last update for some LG infineon CPU,Alcatel MTK, Bird and Samsung so is not only for chinese clone or chinese telephones,
Old 11-08-2008, 05:19   #7 (permalink)
benguetcowboy1's Avatar
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
can also be used as universal interface using the supplied spiderman cables for ex... infinity etc ... no more soldering rx/tx lines
1. open and connect spider
2. define and not save
3. open infinity,furious, etc...
4. set port same as with spider
5. drink beer no need expensive pin or pad finder etc..
The Following 4 Users Say Thank You to benguetcowboy1 For This Useful Post:
Old 11-09-2008, 07:36   #8 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Yes!
You can use any Spiderman Box as a Multiple Definition Data Cable. Just define your RX TX and GND and you can use it with any software as a Data Cable.
Br,
Shadab Ahamd
The Following 2 Users Say Thank You to [Shadab_M] For This Useful Post:
Old 11-10-2008, 02:52   #9 (permalink)
RazoR888's Avatar
Member: 870868
Thanks Meter: 126
so
can i use spiderman to flash/unlock a chinese motorola ?? with a spiderman cables?
which flash file should i use ??
did any body try this ??
Old 11-10-2008, 04:58   #10 (permalink)
Member: 42604
Thanks Meter: 187
Originally Posted by RazoR888 View Post
so
If it is a Chinese Motorola you can try to search phone first..if it can be detected automatically..or try to open the phone to see the CPU inside it might be also supported by Spiderman..
or you can used Spiderman box as interface but don't used the Spiderman soft..
Regards..
Old 11-10-2008, 17:29   #11 (permalink)
muhned's Avatar
Member: 201469
Sonork: software
Thanks Meter: 50
pinfinder with infinty do that ok not spiderman
Old 11-11-2008, 04:38   #12 (permalink)
Member: 42604
Thanks Meter: 187
and who told you it can't be done? do you have a Spiderman box? with due respect to Spiderman Team..
I am using my Spiderman Box together with Infinity...and they work perfectly...
Old 11-12-2008, 04:43   #13 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
I have many boxes on my Store " Spiderman, Infinity +, Universal, SmartClip, Polar, Furius box and for chinese phones some LG, Samsung, Bird, Alcatel etc... The perfect combination is Spiderman and Infinity....
Old 11-16-2008, 16:04   #14 (permalink)
Member: 716195
اريد ملف تثبيت spiderman box
How to use PinFinder for Sagem, LG, SE, Motorola, Pantech, Fly, O2, ZTE etc. Infinity-Box Infinity-Box 309 05-16-2011 02:20
How to use SpiderMan with C702 TV phone, Lucky v10, etc? colpaz SpiderMan 1 01-06-2009 23:40
How to Use Spiderman Box - Flash cect 599 MT6226 KLiFFF SpiderMan 2 09-15-2008 14:17
How to Use Spiderman Box - Flash A88 MT6226 KLiFFF SpiderMan 5 06-23-2008 19:39
How to use patch for DB2020 SE phones? vetas Universalbox 6 03-25-2008 14:28
Page generated in 0.20146 seconds with 9 queries
