07-31-2011, 23:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 598822 Status: Offline Thanks Meter: 74 | How to work MStar CPU with Spiderman !!! So, Now we setting pinouts manually. For this we need five Pins. theyare 1. POWER 2. USB D+ 3. USB D- 4. BOOT 5. GND. Many MStar mobiles come with L5B socket. To this socket Pins set as follows. 1. PWR-4.8v 2. USB - 3. USB + 4. Index_0 5. GND. Almost all L5B sockets has same configuration. My set have L12C socket. Its pin configuration as follows. 2. GND 8. USB D- 9. USB D+ 10. Index_0 12. PWR-4.8v (this configuration differ from phone to phone) READING USER CODE FLASHING: |
The Following 8 Users Say Thank You to inseee For This Useful Post: |
07-31-2011, 23:52 | #2 (permalink) |
Member: 598822 Status: Offline Thanks Meter: 74 | ERASING FLASH WRITING FLASH WRITING SUCCESS. Now Changing of IMEI Numbers Spiderman changing IMEI Numbers in AT Mode means You must Power ON the phone. Data cable once remove and reconnect Now Phone shows below options 1.Pc Camera 2.Modem or PC Connect you select Modem or PC connect option. then your system ask for Modem drivers. Install Modem Drivers (not USB MASS STORAGE Drivers) Now Rebuild IMEI Numbers: |
The Following 6 Users Say Thank You to inseee For This Useful Post: |
08-04-2011, 04:53 | #8 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1615041 Status: Offline Thanks Meter: 0 | Why i see u boxSN is 49617 and Version is 2.54 when i had downloaded newest version of spiderman box is 3.0 Test 2. My boxSN still 47944 and V2.40 ? where i can take new ver and boxSN Last edited by dleviathan; 08-04-2011 at 05:01. |
08-04-2011, 21:49 | #10 (permalink) | |
Member: 598822 Status: Offline Thanks Meter: 74 | Quote:
If you want update firmware of your box, then connect your box to the computer and just click "On line_Update_Box" button in your software.It take below one minute. I updated up to 4 boxes by this method. all are success.My box also come with V2.40. after update change it to V2.54 Do it with Off line mode [no need of internet connection] During update time don't disconnect the box and don't power off until update completed. Note: Take your own risk. I am not responsible for any damage of your box due to failure of update. During update Power failure will be damage your box. | |
The Following User Says Thank You to inseee For This Useful Post: |
08-09-2011, 07:41 | #13 (permalink) |
Major Poster Join Date: Oct 2008
Member: 886441 Status: Offline Sonork: 989090 Thanks Meter: 4 | spiderman.exe- unable to locate component this application has failed to start because ftdxx.dll was not found. re-installing the application may fix this problem. plz help me sir jee |
08-09-2011, 22:21 | #14 (permalink) |
Member: 598822 Status: Offline Thanks Meter: 74 | First SpiderMan box remove and reconnect.When your Computer ask the drivers. then show your drivers.SpiderMan box Drivers are in your C:\SpiderMan_v3.0/Drivers folder.Ftd2xx.dll file is also in SpiderMan_v3.0 \ Drivers \ i386 folder. After install the drivers your problem solved. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
