07-09-2011, 06:37 | #16 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Code: Timer: _2011_7_9_10_10_8>> [MTK] Open COM19 success! Timer: _2011_7_9_10_10_8>> Waitting Enter Meta.. Timer: _2011_7_9_10_10_9>> Press ON/OFF key please Timer: _2011_7_9_10_10_9>> Keep press before done (must)!!! Timer: _2011_7_9_10_10_9>> Press ON/OFF key please... Timer: _2011_7_9_10_10_11>> Target's hw_ver :0x8A05 Timer: _2011_7_9_10_10_11>> Target's hw_code :0x6225 Timer: _2011_7_9_10_10_12>> Target's sw_ver :0x8A00 Timer: _2011_7_9_10_10_13>> [BOOT] Enter META Status Successed! Timer: _2011_7_9_10_10_13>> Phonelock <Locked> Timer: _2011_7_9_10_10_13>> Networklock <not Lock> Timer: _2011_7_9_10_10_13>> Networksublock <not Lock> Timer: _2011_7_9_10_10_13>> serviceprovider<not Lock> Timer: _2011_7_9_10_10_13>> corporatelock <not Lock> Timer: _2011_7_9_10_10_13>> IMSI_lock <not Lock> Timer: _2011_7_9_10_10_13>> Autolock <not Lock> Timer: _2011_7_9_10_10_13>> Phone key:4646 Timer: _2011_7_9_10_10_13>> key[0] state:00->000000000000000000 Timer: _2011_7_9_10_10_13>> key[1] state:00->5678FFFFFFFFFFFF00 Timer: _2011_7_9_10_10_13>> key[2] state:00->000000000000000000 Timer: _2011_7_9_10_10_13>> key[3] state:00->000000000000000000 Timer: _2011_7_9_10_10_13>> key[4] state:00->000000000000000000 Timer: _2011_7_9_10_10_13>> key[5] state:00->000000000000000000 Timer: _2011_7_9_10_10_13>> key[6] state:00->000000000000000000 Timer: _2011_7_9_10_10_14>> [NV] Get private lock Information failed! Timer: _2011_7_9_10_10_14>> Exit MTK Meta Mode Timer: _2011_7_9_10_10_14>> [MTK] Close COM19 success! |
07-14-2011, 07:44 | #18 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Imei Repair Done. Code: Timer: _2011_7_13_5_38_15>> [MTK] Open COM19 success! Timer: _2011_7_13_5_38_15>> Waiting you turn on phone please!!! Timer: _2011_7_13_5_38_15>> The Phone must be trun on! Timer: _2011_7_13_5_38_15>> [IMEI] Enter Test mode Success! Timer: _2011_7_13_5_38_15>> [IMEI] Original IMEI:: "352061021399924" Timer: _2011_7_13_5_38_15>> [IMEI] Success set New IMEI:35396901****** Timer: _2011_7_13_5_38_15>> [IMEI] New IMEI checked:OK Timer: _2011_7_13_5_38_15>> [IMEI] Original IMEI:: "111111111111119" Timer: _2011_7_13_5_38_15>> [IMEI] Success set New IMEI:35396901****** Timer: _2011_7_13_5_38_15>> [IMEI] New IMEI checked:OK B,R. |
07-24-2011, 12:00 | #19 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Format. Code: Timer: _2011_7_23_0_57_33>> [MTK] Open COM19 success! Timer: _2011_7_23_0_57_34>> Press ON/OFF key please... Timer: _2011_7_23_0_57_36>> Target's hw_ver :0x8A03 Timer: _2011_7_23_0_57_36>> Target's hw_code :0x6225 Timer: _2011_7_23_0_57_36>> Target's sw_ver :0x8A00 Timer: _2011_7_23_0_57_37>> Get correct bootloader for target... Timer: _2011_7_23_0_57_37>> MTK_AllInOne_DA_v3.1016.00.00 Timer: _2011_7_23_0_57_37>> DA--->3 is selected! Timer: _2011_7_23_0_57_37>> You can release ON/OFF key! Timer: _2011_7_23_0_57_37>> [DA] loading bootloader 1... Success!Timer: _2011_7_23_0_57_49>> [DA] loading bootloader 2... Success!Timer: _2011_7_23_0_58_0>> [BROM] start to test UART link... Timer: _2011_7_23_0_58_0>> [DA] Check NOR flash IC... Timer: _2011_7_23_0_58_2>> [DA] Check NAND flash IC... Fail!Timer: _2011_7_23_0_58_3>> Waiting the bootloader initilize... Timer: _2011_7_23_0_58_8>> [COM] Success to set baudrate! Timer: _2011_7_23_0_58_8>> [DA] Bootloader running now,OK Timer: _2011_7_23_0_58_8>> [DA] Auto Format Info: Timer: _2011_7_23_0_58_8>> [DA] StartBaseAddr[0xE00000] size[0x200000] Timer: _2011_7_23_0_58_8>> Format with auto index format information Timer: _2011_7_23_0_58_9>> Start to format ... Timer: _2011_7_23_0_58_17>> Format Success! Timer: _2011_7_23_0_58_17>> [MTK] Close COM19 success! Code: Timer: _2011_7_23_0_58_18>> [MTK] Open COM19 success! Timer: _2011_7_23_0_58_18>> Waitting Enter Meta.. Timer: _2011_7_23_0_58_19>> Press ON/OFF key please Timer: _2011_7_23_0_58_19>> Keep press before done (must)!!! Timer: _2011_7_23_0_58_19>> Press ON/OFF key please... Timer: _2011_7_23_0_58_20>> Target's hw_ver :0x8A03 Timer: _2011_7_23_0_58_20>> Target's hw_code :0x6225 Timer: _2011_7_23_0_58_20>> Target's sw_ver :0x8A00 Timer: _2011_7_23_0_58_24>> [BOOT] Enter META Status Successed! Timer: _2011_7_23_0_58_24>> Phonelock <not Lock> Timer: _2011_7_23_0_58_24>> Networklock <not Lock> Timer: _2011_7_23_0_58_24>> Networksublock <not Lock> Timer: _2011_7_23_0_58_24>> serviceprovider<not Lock> Timer: _2011_7_23_0_58_24>> corporatelock <not Lock> Timer: _2011_7_23_0_58_24>> IMSI_lock <not Lock> Timer: _2011_7_23_0_58_24>> Autolock <not Lock> Timer: _2011_7_23_0_58_24>> Phone key:1122 Timer: _2011_7_23_0_58_24>> key[0] state:01->12345678FFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[1] state:10->56781234FFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[2] state:10->1122FFFFFFFFFFFF00 Timer: _2011_7_23_0_58_24>> key[3] state:00->3344FFFFFFFFFFFF00 Timer: _2011_7_23_0_58_24>> key[4] state:00->5566FFFFFFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[5] state:10->7788FFFFFFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[6] state:10->9900FFFFFFFFFFFF1C Timer: _2011_7_23_0_58_24>> [NV] Get private lock Information failed! Timer: _2011_7_23_0_58_24>> Exit MTK Meta Mode Timer: _2011_7_23_0_58_24>> [MTK] Close COM19 success! |
07-24-2011, 12:07 | #20 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Format. Code: Timer: _2011_7_23_0_58_18>> [MTK] Open COM19 success! Timer: _2011_7_23_0_58_18>> Waitting Enter Meta.. Timer: _2011_7_23_0_58_19>> Press ON/OFF key please Timer: _2011_7_23_0_58_19>> Keep press before done (must)!!! Timer: _2011_7_23_0_58_19>> Press ON/OFF key please... Timer: _2011_7_23_0_58_20>> Target's hw_ver :0x8A03 Timer: _2011_7_23_0_58_20>> Target's hw_code :0x6225 Timer: _2011_7_23_0_58_20>> Target's sw_ver :0x8A00 Timer: _2011_7_23_0_58_24>> [BOOT] Enter META Status Successed! Timer: _2011_7_23_0_58_24>> Phonelock <not Lock> Timer: _2011_7_23_0_58_24>> Networklock <not Lock> Timer: _2011_7_23_0_58_24>> Networksublock <not Lock> Timer: _2011_7_23_0_58_24>> serviceprovider<not Lock> Timer: _2011_7_23_0_58_24>> corporatelock <not Lock> Timer: _2011_7_23_0_58_24>> IMSI_lock <not Lock> Timer: _2011_7_23_0_58_24>> Autolock <not Lock> Timer: _2011_7_23_0_58_24>> Phone key:1122 Timer: _2011_7_23_0_58_24>> key[0] state:01->12345678FFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[1] state:10->56781234FFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[2] state:10->1122FFFFFFFFFFFF00 Timer: _2011_7_23_0_58_24>> key[3] state:00->3344FFFFFFFFFFFF00 Timer: _2011_7_23_0_58_24>> key[4] state:00->5566FFFFFFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[5] state:10->7788FFFFFFFFFFFF10 Timer: _2011_7_23_0_58_24>> key[6] state:10->9900FFFFFFFFFFFF1C Timer: _2011_7_23_0_58_24>> [NV] Get private lock Information failed! Timer: _2011_7_23_0_58_24>> Exit MTK Meta Mode Timer: _2011_7_23_0_58_24>> [MTK] Close COM19 success! |
07-27-2011, 11:48 | #30 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2010
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Spreadtrum successfully phonelock code read video spiderman to spd successfully phonelock code read video tutorial by ..::MOBILEPARK::.. |
The Following 6 Users Say Thank You to ..::MOBILEPARK::.. For This Useful Post: |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
