09-07-2011, 16:45 | #76 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Code: Timer: _2011_9_7_8_26_17>> [MTK] Open COM19 success! Timer: _2011_9_7_8_26_18>> Press ON/OFF key please... Timer: _2011_9_7_8_26_19>> Target's hw_ver :0x8A05 Timer: _2011_9_7_8_26_19>> Target's hw_code :0x6225 Timer: _2011_9_7_8_26_20>> Target's sw_ver :0x8A00 Timer: _2011_9_7_8_26_21>> Get correct bootloader for target... Timer: _2011_9_7_8_26_21>> MTK_AllInOne_DA_v3.1016.00.00 Timer: _2011_9_7_8_26_21>> DA--->3 is selected! Timer: _2011_9_7_8_26_21>> You can release ON/OFF key! Timer: _2011_9_7_8_26_21>> [DA] loading bootloader 1... Success!Timer: _2011_9_7_8_26_34>> [DA] loading bootloader 2... Success!Timer: _2011_9_7_8_26_46>> [BROM] start to test UART link... Timer: _2011_9_7_8_26_46>> [DA] Check NOR flash IC... Timer: _2011_9_7_8_26_47>> [DA] Check NAND flash IC... Fail!Timer: _2011_9_7_8_26_49>> Waiting the bootloader initilize... Timer: _2011_9_7_8_26_53>> [COM] Success to set baudrate! Timer: _2011_9_7_8_26_53>> [DA] Bootloader running now,OK Timer: _2011_9_7_8_26_53>> [DA] Auto Format Info: Timer: _2011_9_7_8_26_53>> [DA] StartBaseAddr[0xE00000] size[0x200000] Timer: _2011_9_7_8_26_53>> Format with auto index format information Timer: _2011_9_7_8_26_57>> Start to format ... Timer: _2011_9_7_8_27_8>> Format Success! |
The Following User Says Thank You to ch mobiles For This Useful Post: |
09-07-2011, 16:49 | #77 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Format. Code: Timer: _2011_9_7_14_8_39>> [MTK] Open COM19 success! Timer: _2011_9_7_14_8_40>> Press ON/OFF key please... Timer: _2011_9_7_14_8_41>> Target's new hw_ver :0x8A02 Timer: _2011_9_7_14_8_41>> Target's hw_code :0x6253 Timer: _2011_9_7_14_8_41>> Target's sw_ver :0x8A00 Timer: _2011_9_7_14_8_43>> Get correct bootloader for target... Timer: _2011_9_7_14_8_43>> MTK_AllInOne_DA_v3.1016.00.00 Timer: _2011_9_7_14_8_43>> DA--->9 is selected! Timer: _2011_9_7_14_8_43>> You can release ON/OFF key! Timer: _2011_9_7_14_8_43>> [DA] loading bootloader 1... Success!Timer: _2011_9_7_14_9_12>> [BROM] start to test UART link... Timer: _2011_9_7_14_9_12>> [DA] Check NOR flash IC... Timer: _2011_9_7_14_9_13>> [DA] Check NAND flash IC... Fail!Timer: _2011_9_7_14_9_16>> Waiting the bootloader initilize... Timer: _2011_9_7_14_9_20>> [COM] Success to set baudrate! Timer: _2011_9_7_14_9_20>> [DA] Bootloader running now,OK Timer: _2011_9_7_14_9_20>> [DA] Auto Format Info: Timer: _2011_9_7_14_9_20>> [DA] StartBaseAddr[0xE00000] size[0x200000] Timer: _2011_9_7_14_9_20>> Format with auto index format information Timer: _2011_9_7_14_10_8>> Start to format ... Timer: _2011_9_7_14_10_35>> Format Success! Timer: _2011_9_7_14_10_35>> [MTK] Close COM19 success! Unlock. Code: Timer: _2011_9_7_14_10_42>> [MTK] Open COM19 success! Timer: _2011_9_7_14_10_42>> Waitting Enter Meta.. Timer: _2011_9_7_14_10_43>> Press ON/OFF key please Timer: _2011_9_7_14_10_43>> Keep press before done (must)!!! Timer: _2011_9_7_14_10_43>> Press ON/OFF key please... Timer: _2011_9_7_14_10_44>> Target's hw_ver :0x8A02 Timer: _2011_9_7_14_10_44>> Target's hw_code :0x6253 Timer: _2011_9_7_14_10_44>> Target's new sw_ver :0x8A00 Timer: _2011_9_7_14_10_50>> [BOOT] Enter META Status Successed! Timer: _2011_9_7_14_10_51>> Phonelock <not Lock> Timer: _2011_9_7_14_10_51>> Networklock <not Lock> Timer: _2011_9_7_14_10_51>> Networksublock <not Lock> Timer: _2011_9_7_14_10_51>> serviceprovider<not Lock> Timer: _2011_9_7_14_10_51>> corporatelock <not Lock> Timer: _2011_9_7_14_10_51>> IMSI_lock <not Lock> Timer: _2011_9_7_14_10_51>> Autolock <not Lock> Timer: _2011_9_7_14_10_51>> Phone key:0000 Timer: _2011_9_7_14_10_51>> [NV] Get SIM lock Information failed! Timer: _2011_9_7_14_10_51>> [NV] Get private lock Information failed! Timer: _2011_9_7_14_10_51>> Exit MTK Meta Mode Timer: _2011_9_7_14_10_51>> [MTK] Close COM19 success! |
09-17-2011, 19:13 | #83 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | micrimax x395 imie write done mt 6253cpu MTKTimer: _2011_9_16_23_35_25>> Pinouts find Success! Timer: _2011_9_16_23_35_30>> [MTK] Open COM7 success! Timer: _2011_9_16_23_35_30>> Waiting you turn on phone please!!! Timer: _2011_9_16_23_35_30>> The Phone must be trun on! Timer: _2011_9_16_23_35_30>> [IMEI] Enter Test mode Success! Timer: _2011_9_16_23_35_30>> [IMEI] Original IMEI:: "000000000000000" Timer: _2011_9_16_23_35_30>> [IMEI] Success set New IMEI:91059750310691 Timer: _2011_9_16_23_35_30>> [IMEI] New IMEI checked:OK Timer: _2011_9_16_23_35_30>> [IMEI] Original IMEI:: "000000000000000" Timer: _2011_9_16_23_35_30>> [IMEI] Success set New IMEI:91059750310692 Timer: _2011_9_16_23_35_30>> [IMEI] New IMEI checked:OK Timer: _2011_9_16_23_35_30>> [MTK] Close COM7 success! |
09-18-2011, 17:36 | #84 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Cox's Bazar, Bangladesh
Member: 1481925 Status: Offline Sonork: N/A Thanks Meter: 314 | >>>Long time Read by Spiderman Box<<< Dear, Friends Long Time Readed By Spiderman Box Xksstel-S3 Read time 7.35s Full Read Other Box 3 minis 10s Read. BR, SADEK. |
09-23-2011, 09:08 | #85 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Format. Code: Timer: _2011_9_21_14_53_13>> [MTK] Open COM19 success! Timer: _2011_9_21_14_53_14>> Press ON/OFF key please... Timer: _2011_9_21_14_53_16>> Target's hw_ver :0x8A05 Timer: _2011_9_21_14_53_16>> Target's hw_code :0x6225 Timer: _2011_9_21_14_53_16>> Target's sw_ver :0x8A00 Timer: _2011_9_21_14_53_18>> Get correct bootloader for target... Timer: _2011_9_21_14_53_18>> MTK_AllInOne_DA_v3.1016.00.00 Timer: _2011_9_21_14_53_18>> DA--->3 is selected! Timer: _2011_9_21_14_53_18>> You can release ON/OFF key! Timer: _2011_9_21_14_53_18>> [DA] loading bootloader 1... Success!Timer: _2011_9_21_14_53_32>> [DA] loading bootloader 2... Success!Timer: _2011_9_21_14_53_45>> [BROM] start to test UART link... Timer: _2011_9_21_14_53_45>> [DA] Check NOR flash IC... Timer: _2011_9_21_14_53_47>> [DA] Check NAND flash IC... Fail!Timer: _2011_9_21_14_53_49>> Waiting the bootloader initilize... Timer: _2011_9_21_14_53_54>> [COM] Success to set baudrate! Timer: _2011_9_21_14_53_54>> [DA] Bootloader running now,OK Timer: _2011_9_21_14_53_54>> [DA] Auto Format Info: Timer: _2011_9_21_14_53_54>> [DA] StartBaseAddr[0xE00000] size[0x200000] Timer: _2011_9_21_14_53_54>> Format with auto index format information Timer: _2011_9_21_14_54_4>> Start to format ... Timer: _2011_9_21_14_54_20>> Format Success! Timer: _2011_9_21_14_54_20>> [MTK] Close COM19 success! Code: Timer: _2011_9_21_14_54_24>> [MTK] Open COM19 success! Timer: _2011_9_21_14_54_24>> Waitting Enter Meta.. Timer: _2011_9_21_14_54_25>> Press ON/OFF key please Timer: _2011_9_21_14_54_25>> Keep press before done (must)!!! Timer: _2011_9_21_14_54_25>> Press ON/OFF key please... Timer: _2011_9_21_14_54_25>> Target's hw_ver :0x8A05 Timer: _2011_9_21_14_54_25>> Target's hw_code :0x6225 Timer: _2011_9_21_14_54_25>> Target's sw_ver :0x8A00 Timer: _2011_9_21_14_54_33>> [BOOT] Enter META Status Successed! Timer: _2011_9_21_14_54_35>> Phonelock <not Lock> Timer: _2011_9_21_14_54_35>> Networklock <not Lock> Timer: _2011_9_21_14_54_35>> Networksublock <not Lock> Timer: _2011_9_21_14_54_35>> serviceprovider<not Lock> Timer: _2011_9_21_14_54_35>> corporatelock <not Lock> Timer: _2011_9_21_14_54_35>> IMSI_lock <not Lock> Timer: _2011_9_21_14_54_35>> Autolock <not Lock> Timer: _2011_9_21_14_54_35>> Phone key:1122 Timer: _2011_9_21_14_54_35>> key[0] state:01->12345678FFFFFFFF10 Timer: _2011_9_21_14_54_35>> key[1] state:10->56781234FFFFFFFF10 Timer: _2011_9_21_14_54_35>> key[2] state:10->1122FFFFFFFFFFFF00 Timer: _2011_9_21_14_54_35>> key[3] state:00->3344FFFFFFFFFFFF00 Timer: _2011_9_21_14_54_35>> key[4] state:00->5566FFFFFFFFFFFF10 Timer: _2011_9_21_14_54_35>> key[5] state:10->7788FFFFFFFFFFFF10 Timer: _2011_9_21_14_54_35>> key[6] state:10->9900FFFFFFFFFFFF1C Timer: _2011_9_21_14_54_37>> [NV] Get private lock Information failed! Timer: _2011_9_21_14_54_37>> Exit MTK Meta Mode Timer: _2011_9_21_14_54_37>> [MTK] Close COM19 success! B,R. |
10-03-2011, 12:45 | #87 (permalink) |
Member: 1481925 Status: Offline Sonork: N/A Thanks Meter: 314 | ZTC Format 100% Dear, Friends, ZTC Read, Format 100% By Spiderman Box Model : Pin : Read : Format ..............% Format Succes : Spiderman is very Powerfull Box Because, Other Box not Pinfine Example : T-BOX. So, I hope, Future update is Fix Update. BR, SADEK. |
11-02-2011, 11:04 | #89 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | LG KG 195 Read User Code. Code: Timer: _2011_11_2_14_53_8>> [MTK] Open COM19 success! Timer: _2011_11_2_14_53_8>> Waitting Enter Meta.. Timer: _2011_11_2_14_53_9>> Press ON/OFF key please Timer: _2011_11_2_14_53_9>> Keep press before done (must)!!! Timer: _2011_11_2_14_53_9>> Press ON/OFF key please... Timer: _2011_11_2_14_53_11>> Target's hw_ver :0x8A02 Timer: _2011_11_2_14_53_11>> Target's hw_code :0x6226 Timer: _2011_11_2_14_53_11>> Target's sw_ver :0x8A01 Timer: _2011_11_2_14_53_14>> [BOOT] Enter META Status Successed! Timer: _2011_11_2_14_53_14>> Phonelock <Locked> Timer: _2011_11_2_14_53_14>> Networklock <not Lock> Timer: _2011_11_2_14_53_14>> Networksublock <not Lock> Timer: _2011_11_2_14_53_14>> serviceprovider<not Lock> Timer: _2011_11_2_14_53_14>> corporatelock <not Lock> Timer: _2011_11_2_14_53_14>> IMSI_lock <not Lock> Timer: _2011_11_2_14_53_14>> Autolock <not Lock> Timer: _2011_11_2_14_53_14>> Phone key:24263 Timer: _2011_11_2_14_53_14>> [NV] Get SIM lock Information failed! Timer: _2011_11_2_14_53_15>> [NV] Get private lock Information failed! Timer: _2011_11_2_14_53_15>> Exit MTK Meta Mode Timer: _2011_11_2_14_53_15>> [MTK] Close COM19 success! B,R. |
11-02-2011, 11:23 | #90 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Qlinks Q212 Successfully imei change. Code: Timer: _2011_11_2_13_45_44>> [MTK] Open COM19 success! Timer: _2011_11_2_13_45_44>> Waitting Enter Meta.. Timer: _2011_11_2_13_45_45>> Press ON/OFF key please Timer: _2011_11_2_13_45_45>> Keep press before done (must)!!! Timer: _2011_11_2_13_45_45>> Press ON/OFF key please... Timer: _2011_11_2_13_45_46>> Target's hw_ver :0x8A04 Timer: _2011_11_2_13_45_46>> Target's hw_code :0x6253 Timer: _2011_11_2_13_45_46>> Target's new sw_ver :0x8A00 Timer: _2011_11_2_13_45_53>> [BOOT] Enter META Status Successed! Timer: _2011_11_2_13_45_56>> Old Imei1:35505002098451 Timer: _2011_11_2_13_45_56>> New Imei1:35692503294312 Timer: _2011_11_2_13_45_56>> Old Imei2:35505002098451 Timer: _2011_11_2_13_45_57>> New Imei2:35692503296314 Timer: _2011_11_2_13_45_57>> [MTK] Close COM19 success! B,R. Last edited by ch mobiles; 11-02-2011 at 12:53. |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
