01-24-2008, 11:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 37
Member: 347619 Status: Offline Thanks Meter: 78 | nokia 6233 unlock problem i have tryed for 5 times Code: MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 0/10 SP Lock Status : Locked MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 Backup Already Created...... Preparing To Unlock Phone No. of Unlock Trigger >>>> : 2 Unlock Trigger set to : 1 Unlock Try No. : 1 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... >>> Please connect TP............................. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 1 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 2 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 2 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 3 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 3 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 4 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 4 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 5 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 5 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Try Failed.. Direct Unlock Failed .. Different flash chip/TP Not connected properly.. Set to Learning Mode..... checking Auto Unlock config MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 Backup Already Created...... TP Connection (AD Selected) : AD0 Decrypting ............ Preparing To Unlock Phone ......... Entering Learning Mode..... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 Attempt No. : 0:0:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Important SP Data Not Found .... Not valid instance.. MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 Attempt No. : 1:0:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Sending Unlock Algorithm...... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone to response... Waiting for phone... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:0:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:1:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:1:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:2:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:2:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:3:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 0/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:3:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Important SP Data Not Found .... Not valid instance.. Entering Learning Mode..... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 Attempt No. : 0:0:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Waiting for phone... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 0:0:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 0:1:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Important SP Data Not Found .... Not valid instance.. MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 Attempt No. : 1:0:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 6/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:0:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 7/10 SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 8/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 9/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 1/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 3/3 , 10/10 SP Lock Status : Locked Restoring... please wait..... Please wait.. phone rebooting Restore Done! Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 1/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 2/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 3/10 SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 4/10 SP Lock Status : Locked Failed to Unlock Attempt No. : 1:1:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05.10 21-12-06 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 5/10 SP Lock Status : Locked Important SP Data Not Found .... Not valid instance.. Process Unsuccessfull..Try again... |
01-24-2008, 20:16 | #4 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,214 | Hi you need to use the yellow tp cable on AD 0 and the Black on clk which is black on pin 17 and yellow on pin 27 , HOPE THIS IS CLEARER [IMG][/IMG] PS. I can see in your log that it is clearly TP problem as you where using the wrong tp for Advance box please follow this picutre and use pin 17 and 27 BR FEEL THE POWER Last edited by Fast Unlocking; 01-24-2008 at 20:23. |
01-25-2008, 01:10 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gsm_zone Please report back if you still have problems. As of this moment, AdvanceBox is not using AD1 pin 24 on any phone at all. We only use AD0 which is PIN27 from the right and AD8 which is PIN 41 from the right... 6233 = AD0 Best Regards, X-Shadow |
01-26-2008, 16:42 | #11 (permalink) |
Member: 347619 Status: Offline Thanks Meter: 78 | forget it i unlocked it with upgrading the phone MCU Sw : V 05.43 30-03-07 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 9/10 SP Lock Status : Locked MCU Sw : V 05.43 30-03-07 RM-145 (c) Nokia IMEI : 358975012043924 Please wait reading 308 data C:\Program Files\AdvanceUFS\Autobackup\V 05.43 30-03-07 RM-145 (c) Nokia_358975012043924.pm Preparing To Unlock Phone No. of Unlock Trigger >>>> : 2 Unlock Trigger set to : 1 Unlock Try No. : 1 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... >>> Please connect TP.................................. >>> Please connect TP........................... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.43 30-03-07 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 2/3 , 10/10 SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 1 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.43 30-03-07 RM-145 (c) Nokia IMEI : 358975012043924 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 2042000000000000 Provider : Dutchtone / Orange;Netherlands Counters : 0/3 , 0/10 SP Lock Status : Not Locked Unlocking successfull....... Process Done! .... |
Nokia 6233 MMC Problem......................... | lahoot | Nokia Base Band 5 ( BB-5 ) | 14 | 08-09-2012 14:45 |
nokia 6233 camera problem | pakta4 | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 10-07-2009 16:16 |
nokia 6233 flashing problem (urgent help need) | .::PATEL TELECOM::. | J.A.F. By Jafsupport.com | 4 | 12-07-2008 11:46 |
Nokia 6233, Signals problem, please help | d_t_e | Nokia Hardware & Hardware Repair | 3 | 09-18-2007 10:47 |
Nokia 6233 LoudSpeaker Problem | bbmad | Nokia Hardware & Hardware Repair | 0 | 05-01-2007 23:20 |
