why my advance ufs???????????? - (Problem Solved Sept-08-2008) why my advance ufs can only unlock phone with dku-2 usb connector like 6280 ?????,when i try to connect any phone with small usb connector like 5200 5300 ... i can't do nothing . i can't read phone info ,ican't unlock ,nothing. so my advance ufs detect only phone with dku-2 connector. please if there is any solution, share it and thank you very much. nizoudj |
@nizoudj The Problem should be the cable. Turn on the phone Normally. Try to connect small USB to phone then direct to your PC's USB Port. Then see if Phone is detected by your PC or not. If your PC does not Find the Phone, then your USB cable is damaged... If your PC Finds the Phone then Select USB Connection in AdvanceBox software and SP Unlock your Phone: http://i170.photobucket.com/albums/u...er/222_usb.jpg You can also check your cable: http://i170.photobucket.com/albums/u...r/tp_cable.jpg B.R. X-Shadow |
ok yes it's working thank you so much unlocking like flashing with jaf usb mode thank youo very very much |
