09-22-2008, 19:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: UK
Member: 318507 Status: Offline Thanks Meter: 17 | What is F480 procedure? First try with Microbox I have connected F480 to Microbox and E210 combo cable but the phone is not detected. Does the USB lead have to be plugged in anywhere? Is there a manual anywhere? I haven’t received confirmation email. Does it matter? |
09-22-2008, 19:48 | #2 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Amman Age: 41
Member: 35002 Status: Offline Sonork: 100.98829 Thanks Meter: 167 | samsung f480 unlock done !!! -------------------------------------------------------------------------------- SAMSUNG F480 UNLOCK: START! SEARCHING FOR PHONE: FOUND! READING IMEI: OK! READING FIRMWARE INFO: OK! READING HARDWARE INFO: OK! READING SECURITY DATA: OK! READING UNLOCK DATA: OK! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! SENDING DATA TO SERVER: OK! WAITING FOR SERVER: OK! GETTING UNLOCK DATA FROM SERVER: OK! UNLOCKING: OK! DISCONNECTING FROM SERVER: OK! SAMSUNG F480 UNLOCK: END! bro use rj and usb cable (e210) same ust cable unlock done in 1 min |
09-22-2008, 20:23 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | After you receive your confirmation email you have to download latest software and then update your box firmware, then install samsung cdma drivers, and make sure you set your phone's connection mode to PC Studio in menu, after all these steps you should be able to unlock your phone. Luck |
09-22-2008, 22:49 | #6 (permalink) |
Member: 318507 Status: Offline Thanks Meter: 17 | I downloaded PC Studio (it took about 1 hour) and tried again: SAMSUNG F480 UNLOCK: START! SEARCHING FOR PHONE: FOUND! READING IMEI: OK! READING HARDWARE INFO: OK! READING FIRMWARE INFO: OK! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: NOT ACCEPTED! (PLEASE USE LAST SOFTWARE VERSION!) DISCONNECTING FROM SERVER: OK! SAMSUNG F480 UNLOCK: END! I still haven't received conformation email. |
09-22-2008, 23:12 | #7 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | Quote:
The solution is there m8, use last version, you can check it here http:///vbb/showthread.php?t=483193 For confirmation email, try to login with your user/pass, sometimes the email is redirected to spam folder by your mail provider. | |
09-22-2008, 23:19 | #8 (permalink) |
Member: 318507 Status: Offline Thanks Meter: 17 | Thank you all for great help. Microbox has been activated and I got this: SAMSUNG F480 UNLOCK: START! SEARCHING FOR PHONE: FOUND! READING IMEI: OK! READING FIRMWARE INFO: OK! READING HARDWARE INFO: OK! READING SECURITY DATA: OK! READING UNLOCK DATA: OK! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! SENDING DATA TO SERVER: OK! WAITING FOR SERVER: OK! GETTING UNLOCK DATA FROM SERVER: OK! UNLOCKING: OK! DISCONNECTING FROM SERVER: OK! SAMSUNG F480 UNLOCK: END! I have one more problem. Phone asks for password to enter menu options. Can I read codes? Or is there a standard password? I also have NsPro but F480 is not supported. Can I read codes using a different phone model? |
09-22-2008, 23:29 | #9 (permalink) | |
10-02-2008, 14:29 | #12 (permalink) |
Member: 318507 Status: Offline Thanks Meter: 17 | Logs not needed for this phone. Have you activated box and unlocked any phones yet? If yes, just make sure you have the latest version of the software and follow the instructions. |
10-02-2008, 17:16 | #13 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | password to enter menu can't be read by Micro-Box , ( also no box can do it until now and via rest don't succeed i am still searching for solution ) |
First try with Vygis to unlock KE970 | justmegt | VygisToolbox | 6 | 12-05-2007 01:10 |
What is the procedure for unlock bb5 with UID box | Amit Tank | UID - Box | 7 | 09-20-2007 15:27 |
what is the procedure for changing band in bb | uqbah | FuriousGold | 1 | 07-07-2006 11:41 |
what is the procedure change imei j300i | Amit Tank | Cruiser Suite | 0 | 06-09-2006 06:40 |
First try with Phoenix | Bernie | Phoenix Black Box | 13 | 06-09-2005 11:26 |
