01-25-2009, 22:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | cant unlock or flash kg800 |
01-27-2009, 02:59 | #3 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | here is the log file## LG KG800 UNLOCK: START! PRESS POWER: ABORTED! LG KG800 UNLOCK: END! LG KG800 UNLOCK: START! PRESS POWER: OK! DON'T RELEASE POWER! SENDING BOOT: OK! RELEASE POWER! SPEED CHANGED TO: 115200! READING FLASH ID: ERROR! LG KG800 UNLOCK: END! LG KG800 UNLOCK: START! PRESS POWER: ABORTED! LG KG800 UNLOCK: END! LG KG800 UNLOCK: START! PRESS POWER: OK! DON'T RELEASE POWER! SENDING BOOT: OK! RELEASE POWER! SPEED CHANGED TO: 115200! READING FLASH ID: ERROR! LG KG800 UNLOCK: END! |
01-27-2009, 04:47 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Have you tried pressing the power button the whole process, i mean, keep it pressed until software finishes reading all the info, try not use usb hubs for phone and box, battery should be charged (50% at least), also if you have another cable try it, luck Last edited by y3kt; 01-27-2009 at 04:51. Reason: Missing suggestions |
The Following User Says Thank You to y3kt For This Useful Post: |
2610b 7.4a Cant Unlock or flash | Chennairam | Universalbox | 1 | 02-20-2009 19:37 |
CU500 bad spc cant unlock or flash | PILONCILLO | FuriousGold | 1 | 04-25-2008 23:33 |
i cant unlock or flash dct4 phones with griffin | ADD-GSM | Griffin | 2 | 03-19-2004 12:07 |
