10-04-2016, 12:35 | #1 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 427167 Status: Offline Sonork: 100.1670875 Thanks Meter: 48 | Need urgent help, fix server error. [SOLVED] 14:32:24 > Checking server 1: OK! 14:32:24 > Connecting to server: OK! 14:32:25 > Asking server for access: ERROR!NOT ACCEPTED! 14:32:25 > NOT IN SERVER! 14:32:25 > Disconnecting from server: OK! |
10-04-2016, 12:47 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Please can give more details, like what box/dongle are using, what version, what activaction have itc.... Server is working Fine, tested in this moment, ceck you Internet connection or other issue from you side please!!! Br allumts Last edited by allumts; 10-04-2016 at 12:53. |
10-04-2016, 12:59 | #5 (permalink) |
Member: 427167 Status: Offline Sonork: 100.1670875 Thanks Meter: 48 | As you see it write 14:32:24 > Checking server 1: OK! 14:32:24 > Connecting to server: OK! Server answer NOT ACCEPTED. Internet work perfectly. Can this issue related with access to server with my sn only? 15:00:28 > SYNC WITH SERVER: START! 15:00:29 > Reading ACTIVATIONS: OK! 15:00:30 > Checking server 1: OK! 15:00:31 > Connecting to server: OK! 15:00:31 > Asking server for access: ERROR! NOT ACCEPTED! 15:00:31 > NOT IN SERVER! 15:00:32 > Disconnecting from server: OK! 15:00:32 > SYNC WITH SERVER: END! I write my sn to pm |
10-04-2016, 13:05 | #6 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | You have done any error in Activaction of Microbox SW on Infinity, please disconnect all other Box when run this, ceck if all Drivers are installed, YOU CANNOT enter in Server only with S/N, only by Sw can enter.... and loock here carefully: Activate Micro-box on Infinity-box - MICRO BOX V3.0 THE BEST MULTI PLATFORM UNLOCKING TOOL ! BR |
10-04-2016, 13:24 | #7 (permalink) |
Member: 427167 Status: Offline Sonork: 100.1670875 Thanks Meter: 48 | Software work perfectly since june when it be activated, now i try another provider and another PC, and the error still the same. May be better write to support email? Last edited by cloud-81; 10-04-2016 at 13:33. |
10-04-2016, 13:37 | #8 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR | |
