12-05-2016, 18:12 | #1 (permalink) |
Junior Member Join Date: Mar 2007
Member: 478801 Status: Offline Thanks Meter: 2 | m9 sprint unlock boot Code: 23:40:27 > MODEL: HTC_HIMAWL 23:40:27 > IMEI: 990005024452477 23:40:27 > MID: 0PJA30000 23:40:27 > BOOT LOADER: 1.0.0.0000 23:40:27 > VERSION: 1.0 23:40:27 > FIRMWARE: 3.37.605.7 / 2.15.C1144077@60105 23:40:27 > BATTERY STATUS: GOOD 23:40:28 > SPRINT HTC One M9 READ INFO: END! Code: 23:42:24 > Reading data: ERROR! [ OEM LOCK ] 23:42:24 > 1. Power ON phone in Android 23:42:24 > 2. Go to Settings -> Developer options 23:42:24 > 3. Check OEM Unlocking and Enable! 23:42:24 > SPRINT HTC One M9 UNLOCK BOOTLOADER: END! Code: 00:09:58 > Checking server 1: OK! 00:09:59 > Connecting to server: OK! 00:10:02 > Asking server for access: OK! 00:10:02 > Disconnecting from server: OK! 00:10:03 > Searching for device: ABORTED! |
12-06-2016, 12:21 | #3 (permalink) |
Member: 478801 Status: Offline Thanks Meter: 2 | fastboot info htc cable 2 not connect Code: 18:18:10 > Checking server 1: OK! 18:18:11 > Connecting to server: OK! 18:18:14 > Asking server for access: OK! 18:18:14 > Disconnecting from server: OK! 18:18:14 > SPRINT HTC 0PM920000 READ INFO: START! 18:18:14 > Searching for phone: 18:18:39 > Loading device driver dll: OK! 18:18:39 > Checking device driver dll version: OK! 18:18:39 > Checking device driver version: OK! 18:19:39 > Searching for device: ERROR! [ NOT_FOUND ] Code: 18:12:52 > SPRINT HTC 0PM920000 READ INFO: START! 18:12:52 > KILLING ADB SERVER (IF RUNNING): OK! 18:12:53 > Searching for phone: OK! 18:12:55 > Reading info: OK! 18:12:55 > MODEL: HTC_HIMAWL 18:12:55 > IMEI: 990005024452477 18:12:55 > MID: 0PJA30000 18:12:55 > BOOT LOADER: 1.0.0.0000 18:12:55 > VERSION: 1.0 18:12:55 > FIRMWARE: 3.37.605.7 / 2.15.C1144077@60105 18:12:55 > BATTERY STATUS: GOOD 18:12:56 > SPRINT HTC 0PM920000 READ INFO: END! |
12-06-2016, 13:05 | #4 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, but you connect Phone in "fastboot mode" first of try to "Unlock Bootloader"? Htc Sprint aren't supported for any operation but for Unlock Bootlader Yes, so No try to Read info or other things, go direct in "Unlock Bootloader" tabulate, set right phone and Unlock Bootloader. Then go in "Bootloader Unlock" tabulate, use "fastboot device/usb" then press "Unlock Bootloader". |
12-06-2016, 15:36 | #5 (permalink) |
Member: 478801 Status: Offline Thanks Meter: 2 | not unlock bootloader . OEM lock Code: 21:34:37 > Please connect phone to usb in fastboot mode! 21:34:38 > Searching for phone: OK! 21:34:39 > Reading info: OK! 21:34:39 > MODEL: HTC_HIMAWL 21:34:39 > IMEI: 990005024452477 21:34:39 > MID: 0PJA30000 21:34:39 > BOOT LOADER: 1.0.0.0000 21:34:40 > VERSION: 1.0 21:34:40 > FIRMWARE: 3.37.605.7 / 2.15.C1144077@60105 21:34:40 > BATTERY STATUS: GOOD 21:34:40 > Reading data: ERROR! [ OEM LOCK ] 21:34:40 > 1. Power ON phone in Android 21:34:40 > 2. Go to Settings -> Developer options 21:34:40 > 3. Check OEM Unlocking and Enable! 21:34:40 > SPRINT HTC One M9 UNLOCK BOOTLOADER: END! |
