Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 07-06-2012, 21:17   #1 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
Error read code s5620 [Answered]
Other phone with error:
I read perfect by usb cable, but for unlock no work with usb cable only rj45
MODEL: SAMSUNG S5620
JOB: READ UNLOCK CODES
CABLE: MICROUSB UART (RJ45)
POWER: OFF
16:11:06 > VERSION MICRO-BOX A.I.O. V2.1.0.9
16:11:06 > SAMSUNG S5620 READ INFO: START!
16:11:06 > READING MODEL: OK!
16:11:06 > READING IMEI: OK!
16:11:06 > READING VERSION: OK!
16:11:06 > READING HARDWARE INFO: OK!
16:11:06 > MODEL: GT-S5620B
16:11:06 > IMEI: 352058040XXXX61
16:11:06 > COUNTRY CODE: ZVV
16:11:06 > VERSION: Hedge Platform: BCM2153_SI1.3.56_V01.1_P053_R0.0
16:11:06 > FIRMWARE: VIJB2_JC4
16:11:06 > HARDWARE: MP0.400
16:11:06 > MSL ADDRESS: RS4Z484902
16:11:06 > PHONE SN: 78030000334900
16:11:06 > BT ADDR: 34 C3 AC 23 E1 91
16:11:06 > DATE: 2010-03-30
16:11:06 > MEMORY NAME: K5R4G1GACM(S5620)S
16:11:06 > SAMSUNG S5620 READ INFO: END!
16:11:09 > VERSION MICRO-BOX A.I.O. V2.1.0.9
16:11:09 > SAMSUNG S5620 READ CODES: START!
16:11:20 > PRESS POWER: ERROR!(TIMEOUT)
16:11:20 > SAMSUNG S5620 READ CODES: END!
16:11:26 > VERSION MICRO-BOX A.I.O. V2.1.0.9
16:11:26 > SAMSUNG S5620 READ CODES: START!
16:11:29 > PRESS POWER: OK!
16:12:00 > SENDING LOADER: OK!
16:12:32 > READING DATA: ERROR 1002!
16:12:32 > SAMSUNG S5620 READ CODES: END!
16:12:43 > VERSION MICRO-BOX A.I.O. V2.1.0.9
16:12:43 > SAMSUNG S5620 READ CODES: START!
16:12:45 > PRESS POWER: OK!
16:13:16 > SENDING LOADER: OK!
16:13:47 > READING DATA: ERROR 1002!
16:13:47 > SAMSUNG S5620 READ CODES: END!
What problem? I'm too dumb or really can not use more Microbox or she does not work perfectly!
Old 07-06-2012, 21:41   #2 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
Bug, Bug Bug in latest version,
old version green at least makes reading more forward, Microbox Bug, bug, bug or my box with problem
16:33:09 > VERSION MICRO-BOX A.I.O. V2.0.4.5
16:33:09 > SAMSUNG S5620 READ CODES: START!
16:33:12 > PRESS POWER: OK!
16:33:42 > SENDING LOADER: OK!
16:33:50 > READING DATA: OK!
16:34:03 > MODEL: GT-S5620B
16:34:03 > COUNTRY CODE: ZVV
16:34:03 > FIRMWARE: VIJB2_JC4
16:34:03 > PHONE SN: 78030000334900
16:34:03 > DATE: 2010-03-30
16:34:03 > MEMORY NAME: K5R4G1GACM(S5620)S
16:34:03 > CHECKING SERVER 1: OK!
16:34:04 > CONNECTING TO SERVER: OK!
16:34:05 > ASKING SERVER FOR ACCESS: ACCEPTED!
16:34:06 > SENDING DATA TO SERVER: OK!
16:37:06 > CALCULATING [BY SERVER] PLEASE WAIT: ERROR 1003!!
16:37:06 > DISCONNECTING FROM SERVER: OK!
16:37:07 > SAMSUNG S5620 READ CODES: END!
Old 07-09-2012, 13:27   #3 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
I need help Microbox
Old 07-09-2012, 13:42   #4 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
All red version have bug, old green version work perfect
For too long, try to use my box, but with these errors difficult ta all my luck I have a lot of equipment
08:38:51 > VERSION MICRO-BOX A.I.O. V2.1.0.9
08:38:51 > SAMSUNG S5620 READ CODES: START!
08:38:52 > PRESS POWER: OK!
08:39:23 > SENDING LOADER: OK!
08:39:55 > READING DATA: ERROR 1002!
08:39:55 > SAMSUNG S5620 READ CODES: END!
08:40:50 > VERSION MICRO-BOX A.I.O. V2.1.0.9
08:40:51 > SAMSUNG S5620 READ CODES: START!
08:40:57 > PRESS POWER: OK!
08:41:27 > SENDING LOADER: OK!
08:41:59 > READING DATA: ERROR 1002!
08:41:59 > SAMSUNG S5620 READ CODES: END!
08:35:36 > VERSION MICRO-BOX A.I.O. V2.0.5.6
08:35:36 > SAMSUNG S5620 READ CODES: START!
08:35:38 > PRESS POWER: OK!
08:36:08 > SENDING LOADER: OK!
08:36:16 > READING DATA: OK!
08:36:26 > MODEL: GT-S5620B
08:36:26 > COUNTRY CODE: ZVV
08:36:26 > FIRMWARE: VIJB2_JC4
08:36:26 > PHONE SN: 78030000XXXXX0
08:36:26 > DATE: 2010-03-30
08:36:26 > MEMORY NAME: K5R4G1GACM(S5620)S
08:36:27 > CHECKING SERVER 1: OK!
08:36:27 > CONNECTING TO SERVER: OK!
08:36:29 > ASKING SERVER FOR ACCESS: ACCEPTED!
08:36:30 > SENDING DATA TO SERVER: OK!
08:36:34 > CALCULATING [BY SERVER] PLEASE WAIT: OK!
08:36:34 > CP CODE: #7465625*27*00000000#
08:36:34 > SP CODE: #7465625*77*00000000#
08:36:34 > SIM CODE: #7465625*782*00000000#
08:36:34 > NET CODE: #7465625*638*60730626#
08:36:34 > FREEZE CODE: 93753958 (Insert not accepted simcard press call and type the code)
08:36:34 > DISCONNECTING FROM SERVER: OK!
08:36:34 > SAMSUNG S5620 READ CODES: END!
Old 07-10-2012, 09:44   #5 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
What fw you have on red box ?
WBR,
gsm9l
Old 07-10-2012, 15:06   #6 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
I don't have red box, I have micro box old box black
11:06:03 > READ BOX INFO: START!
11:06:05 > SEARCHING FOR BOX: FOUND MICRO-BOX!
11:06:05 > READING MICRO-BOX SN: OK!
11:06:05 > READING MICRO-BOX VERSIONS: OK!
11:06:05 > READING ACTIVATIONS FROM BOX: OK!
11:06:05 > MICRO-BOX SN: AB942DF8XXXXX502
11:06:05 > MICRO-BOX FW: 75
11:06:05 > BOOT VERSION: 50
11:06:05 > ALCATEL: ACTIVATED!
11:06:05 > BLACKBERRY: ACTIVATED!
11:06:05 > HTC: ACTIVATED!
11:06:05 > LG: ACTIVATED!
11:06:05 > SAGEM: ACTIVATED!
11:06:05 > READ BOX INFO: END!
Old 07-12-2012, 08:01   #7 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Ok now I understand the problem we will check it. Thanks for reporting it.
WBR,
gsm9l
The Following User Says Thank You to gsm9l For This Useful Post:
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-26-2012 04:40
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
Page generated in 0.16390 seconds with 9 queries
