08-19-2008, 18:51 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | problem with sagem myc5-3 D75I685ASx - it's M62+ Sec SAGEM MYC5-3 READ CODES: START! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! GETTING CREDIT DATA FROM SERVER: OK! CREDIT USED: 7 CREDIT LIMIT: 25 SEARCHING FOR PHONE: FOUND! READING FIRMWARE INFO: OK! READING HASH TABLE INFO: OK! READING IMEI: OK! READING MODEL INFO: OK! PRESS POWER: OK! READING CPU INFO: OK! LOADING CERTIFICATE: OK! LOADING APPLICATION: ERROR 1002! SAGEM MYC5-3 READ CODES: END! after 100 % error ??????????????????????????????????????????? how to solve problem |
08-19-2008, 19:38 | #2 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | Quote:
08-19-2008, 20:37 | #3 (permalink) |
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | good job problem OK MODEL: MYC5-3 IMEI: 352179015488709 CODE: 37301848-72 GETTING CREDIT DATA FROM SERVER: OK! CREDIT USED: 8 CREDIT LIMIT: 25 SAGEM MYC5-3 READ CODES: END! |
The Following User Says Thank You to adelgsm For This Useful Post: |
08-22-2008, 18:16 | #4 (permalink) |
Registered User Join Date: Jan 2006
Member: 219851 Status: Offline Thanks Meter: 0 | boot loader failed sir when i tried myc5-3 on dd with it's cable then after 40%;30% it says error" boot loader failed " every time. i had used full charged battery also . checked the test points also. kinbdly solve my prob. |
08-22-2008, 19:12 | #5 (permalink) |
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | Check phone cpu, if it is written on it D75I685ASx so you can unlock this phone by log and simple myC2 universal cable, with microbox or with dd |
08-23-2008, 09:25 | #6 (permalink) |
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | Originally Posted by midou01 Check phone cpu, if it is written on it D75I685ASx so you can unlock this phone by log and simple myC2 universal cable, with microbox or with dd It is just its |
my501c D75I685ASx - it's M62+ Sec. problem | James-R | SAGEM JTAG UNLOCKER | 6 | 09-03-2009 17:07 |
problem with sagem MyC5-3 | renanhube | Sagem Hardware Repair Area | 1 | 02-27-2009 05:10 |
Need pinout for a sagem myc5-3 to use with infinder? | The Repair Shop | SAGEM JTAG UNLOCKER | 1 | 01-31-2009 13:52 |
** cannot unlock sagem myc5-3 with prolific cable ** | moni108 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 7 | 01-24-2009 11:22 |
Strange problem with SAGEM MYC5-2 | Steamroller | Sagem Hardware Repair Area | 12 | 11-02-2008 02:14 |
