12-10-2020, 16:05 | #1 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: UK
Member: 196365 Status: Offline Thanks Meter: 35 | Sagem my501c successfully unlocked (CPU: D75I685ASx) [Good Success] speed: 115200 cable soldered: tx,rx,gnd to RJ45 microbox port Quote:
Currently SagemDD, SMTi Sagmaster are dead projects, You're the one who can still make it :-) | |
The Following User Says Thank You to mahcin For This Useful Post: |
12-10-2020, 22:37 | #3 (permalink) |
Member: 196365 Status: Offline Thanks Meter: 35 | I think the most common problem is cable connection. I had many errors too, but more likely it's due to lack of connection for micro seconds between mainboard and microbox. Microbox read data and send to server for calculation. If DATA is wrong then reply from server is empty or "ERROR" by my understanding. It could be even 1bit wrong to make it happens, I think. When I have used clip to hold mainboard+battery together and tweezers to short power button and basically phone was totally stationary then I have read above code (log) several times OKAY. Same cable, same box, but slightly different personal setup to make it succesfull. I have seen some informations in some posts in the past blaming that microbox is not doing my501c at all because someone tried several phones etc etc and nothing positive... false statement, I like work with Sagems, Microbox does the job, just firstly I prefer to open phone and check if that's D75I685ASx CPU, then do the job, because if that's "Z" CPU then obviously it won't work due to different read/write technique. |
12-11-2020, 09:53 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br Allumts | |
