02-27-2014, 17:33 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | N9005 problem unlocking phone is new with this version 4.3 after trying to reset EFS he give m error i try with flash v 4.2.2 now i can reset efs but i NOT CONCTED WITH UART --MODEM who to unlock it |
02-27-2014, 22:34 | #6 (permalink) |
Member: 39250 Status: Offline Thanks Meter: 64 | PUT THE PHONE DOWNLOAD MODE CONNECT USB CABLE GO TO DEVICE MANAGER(PC) CHECK MODEM PORT NUMBER SELECT THE MODEM PORT WITH SPT THEN USE RESET "EFS" OPTION AFTER RESET EFS PHONE WILL REBOOT DISCONNECT PHONE FROM USB CABLE CONNECT UART CABLE ALSO SELECT BOX PORT NUMBER WITH SPT SOFTWARE. COPY "SUPER IMEI" FILL THE REPAIR IMEI AREA ALSO MARK "UNLOCK" OPTION THEN USE "FACTORY MODE" AFTER THE FACTORY MODE PHONE AGAIN TO REBOOT MAKE SURE SUPER IMEI WRITE THE PHONE I know that but after reset efs i select super imei repair imei and unlock but phone no connected All is good i have change cables but problem is some |
