flashing n9005..? hi i need to go back to 4.x firmware from 5 firmare in a note 3.i decided to flash the phone with a file in the support page but when i scroll to select n9005 i cant find it anywhere! please am i doing something wrong or this phone isnt supported? thanks a lot in advance |
if there is no file on support Area,than you can use Odin flasheble file to flash with spt. you can also flash your device with Odin. |
i didnt say that there is no flash file in the support page,i said that i downloaded the correct flash files but i cant use spt box to flash it cause it looks like this model isnt supported? |
what's the build number of the phone? |
LRX21V.N9005XXUGB0B6 can i ask u why u need it? |
Why Don't you post screen shot .? It is supported since spt card 16.9.8,if you use Newly Ver. And it's not Allow to select file in Field,than try with Spt old Ver. |
ok i was able to flash the phone,the procedure was fine but now the phone stays doesnt even starts....is there a right procedure to flash it?or perhaps i need to check some parameters before flashing it in order to make it work? thanks a lot |
also why the imei is always null after the flash procedure? :( |
so the right procedure would be: 1)flash to 4.4.2 with spt box 2)flast to 4.3 with odin and put the language i need 3) repair imei does this procedure make sense? |
