Help imei Samsung GT-S3370L[ANSWERED] hi, who can help with the procedure for imei and unlock for this model, thanks to everyone for the contribution |
just select s3370 and press read then after over read dump put here link and we added next update imei and unlock for this model |
please helpme whit s3370l : dump s3370l |
whit model s3370l: unlock: Detect Qualcomm Modem Connect ... Qualcomm Modem Connect OK. Detect Comport Connect ... Comport Connect OK. SW Ver: S3370LUBJE1 IMEI: 353339040359577 Product ID: Q6270B-KPVZL-1.5.55011ST Phone SN: RVAZ809834 Phone Firmware Not Support ! Set MSL Code Failure ! Total Time: 37.59 s ------------------------------ phone lock: Detect Modem Connect Failure ! Total Time: 2.57 s |
i flash whit fash support spd put have some problem: Detect Qualcomm Modem Connect ... Qualcomm Modem Connect OK. Detect Comport Connect ... Comport Connect OK. SW Ver: S3370AOJH1 IMEI: 353339040359577 Product ID: Q6270B-KPVZL-1.5.55011ST Phone SN: RVAZ809834 Phone Firmware Not Support ! Set MSL Code Failure ! Total Time: 48.64 s |
pls press read botton dump and upload dump files we will add this versions B.R |
dump s3370l |
But witch version this DUMP is becosue you give logs from 2 versions and we need know from witch one this DUMP is readed. Witch version is dump this : SW Ver: S3370LUBJE1 or from this phone : SW Ver: S3370AOJH1 ?? ?? ?? |
i flash whit SW Ver: S3370AOJH1 _some error ,in both sw ver,original and flash the your support put the dump is original sw ver: S3370LUBJE1 |
You cant flash S3370 to S3370L you wont have signal after flashed |
this is log whit firmaware original: Detect Qualcomm Modem Connect ... Qualcomm Modem Connect OK. Detect Comport Connect ... Comport Connect OK. SW Ver: S3370LWAJE1 IMEI: 353339040419355 Product ID: Q6270B-KPVZL-1.5.55011ST Phone SN: RUCZ849619 Phone Firmware Not Support ! Set MSL Code Failure ! Total Time: 55.57 s this is after flash firm the support: Detect Qualcomm Modem Connect ... Qualcomm Modem Connect OK. Detect Comport Connect ... Comport Connect OK. SW Ver: S3370AOJH1 IMEI: 353339040359577 Product ID: Q6270B-KPVZL-1.5.55011ST Phone SN: RVAZ809834 Phone Firmware Not Support ! Set MSL Code Failure ! Total Time: 48.64 s in both is the some problem tested in 2 cell |
