Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 02-28-2010, 21:47   #1 (permalink)
Member: 188484
Thanks Meter: 117
i900 omnia MONAHAN.. [SOLVED]
I try flash this phone but phone dead.Flashing succesfull but phone dead MONAHAN problem.I have omnia repair but wath hapend ? and how flashing this phone.
Old 02-28-2010, 22:55   #2 (permalink)
Member: 535033
Sonork: 100.45908
Thanks Meter: 18,871
its normaly no way to kill phone if u make right procedure with full battery but battery or driver problem have its will kill phone original software to same
Old 02-28-2010, 23:00   #3 (permalink)
Member: 535033
Sonork: 100.45908
Step by Step here Flashing i900 and windows mobile omap phones.
* Check Battery
* Install Activesync
* Open Software
* Select Model
* Press Rescan Port
* Select Port Auto Speed Usb
* Select All File
* Press Write
* When Sw Said Press Power on Then Connect Phone to Usb Cable And Press Power on Keep Hand to see omnia logo
* If You Flashing First Time its Half To Flashing will ask Driver then install driver and sw can give error after install driver
* Then If Get Error After Driver Installation Make It All Procedure again its will flashing success
B.R
The Following 2 Users Say Thank You to SPTTEAM For This Useful Post:
Old 03-01-2010, 05:33   #4 (permalink)
Member: 188484
Thanks Meter: 117
Ok .I have to fix your phone and try again. a question. This flash contains Romanian languaje for phone ? I900XFHJ1_IA1.rar
Old 03-01-2010, 09:54   #5 (permalink)
Member: 535033
Sonork: 100.45908
yes must be XFHJ1 but not sure
B.R
Old 03-01-2010, 12:02   #6 (permalink)
Member: 188484
Thanks Meter: 117
RESOLVED with omnia and thanks SPTTEAM for help.flashing ok with you help.
I flashing with this flash seting region romania but not have romanian language .
Old 03-02-2010, 09:59   #7 (permalink)
Member: 535033
Sonork: 100.45908
yes some time omnia not active language we work on it if find problem will fix it soon
B.R
i900 omnia tr language not support flash file[SOLVED] turkcellgsm SPT BOX 2 01-22-2010 19:48
OMNIA Monahans problem with OMNIA REPAIR TOOL Nustian QUALCOMM Models (3G) 17 01-05-2010 21:49
i900 dead monahans drivers detected on pc saajith UST Pro II 4 10-02-2009 15:07
Page generated in 0.13588 seconds with 9 queries
