07-10-2014, 20:17 | #2 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Spain
Member: 1683011 Status: Offline Thanks Meter: 27 | here network working ok but wifi connectiing disconnecting , not connect, if write original imei back then wifi work perfect but with superimei not working wifi, any help. thanks hardcopper |
07-11-2014, 12:28 | #4 (permalink) |
Member: 1683011 Status: Offline Thanks Meter: 27 | My sim card works ok, I tested all superimei avaliable in software, when unlock phone , wifi start connecting disconnecting, but doesnt connect, gives autentication error, when put original imei back, no network, but wifi connects perfectly without any problem, flashed the phone but same , after unlock wifi problem, if repair imei back to original then no network, any suggestions hardcopper |
07-11-2014, 12:56 | #5 (permalink) |
Member: 1683011 Status: Offline Thanks Meter: 27 | Got 2 pcs this firmware version G3815XXUBMK5 but not working unlock , reset efs done but with rj 45 always, Please Wait Enter Test Mode ... Timeout ! Total Time: 18.20 s rooted also , but still same any help. |
07-16-2014, 11:55 | #6 (permalink) |
Member: 1683011 Status: Offline Thanks Meter: 27 | No comments , nothing from spt team, no questions from product supporter where are they. the version in support I cannot flash phone from G3815XXUBMK5 to mj1 or the firmware in support, phone gets error in writing boot, so please make a patch that works for all firmwares. thanks hardcopper |
07-17-2014, 06:42 | #7 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 41
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | Bcoz ur firmware is newr then support or try without flashing bootloader .. if wi-fi problem flash latest frimware and then try again |
