04-29-2014, 21:17 | #48 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If you have Infinity-Box or BEST or CDMA-Tool - contact to [email protected] |
04-29-2014, 21:18 | #49 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | |
04-29-2014, 21:18 | #50 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If you have Main Infinity-Box or BEST or CDMA-Tool - contact to [email protected] |
04-29-2014, 21:19 | #51 (permalink) |
06-26-2014, 14:54 | #52 (permalink) |
No Life Poster Join Date: May 2003
Member: 28819 Status: Offline Thanks Meter: 222 | hello i cant go in support for downlode flash pls reset my acccount spt searching dongle... dongle found firmware version: 0004 SPT-Box serial number (S/N): 00002D294CB8DE4D (11561) dongle hardware serial: 000ADBF9FF021982 ==> SPT-Box S/N: 00002D294CB8DE4D (11561) thx |
06-27-2014, 12:54 | #53 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
This thread name is SPT-Box Software Activations for Infinity-Box products but you have SPT-Box but not Activation for Infinity. You must contact to your reseller or to spt support directly. | |
07-29-2014, 09:10 | #54 (permalink) |
Freak Poster Join Date: Jan 2006 Location: India (Gujarat) Age: 36
Member: 223135 Status: Offline Sonork: 100.1592685 Thanks Meter: 177 | Pls Help Me SIr Cant Active Dongle 2014.07.29 08:07:39 103.250.165.124 : register : serial [00003BE16E******, 1****] should be activated via reseller ! Wrong reply from server: 2014.07.29 08:07:39 103.250.165.124 : register : serial [00003BE16E5*****, 1****] should be activated via reseller ! Contact to [email protected] Failed: 00003BE16E5***** BR Uttam |
07-30-2014, 12:20 | #55 (permalink) | |
08-10-2014, 11:19 | #56 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
how to login as Administrator ini win8.1? can you guide step by step how its work? thanks in advance | |
08-10-2014, 11:33 | #57 (permalink) | |
i already did it like you said, run pc as administrator in my win8.1 and copy user.ini, but spt program stil cant find my infinitybox comport? how i solve this problem? thanks ini advance | |
08-11-2014, 09:38 | #58 (permalink) | |
So, you can run SPT software but COM port is not found. Right ? If yes: you must install FTDI VCP drivers: http://www.ftdichip.com/Drivers/VCP.htm After that you will see COM port in your PC Device Manager and in software. | |
08-13-2014, 06:58 | #59 (permalink) | |
am already have driver you said n already instal it, i can see com port infinity, n my infinitybox can run n work good, but if i run spt program, then i select com port. in spt program i only see auto comport, but cant see infinity comport as the base | |
08-13-2014, 20:27 | #60 (permalink) | |
Its quite strange that you can not select COM port in SPT software. Please post here SPT software screenshot. Also, do you have any other box/cables ? | |
