03-09-2014, 17:55 | #1 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | Wifi problem after unlock/default efs/imei? Solution here Tested in Note3 sm-n900 and S4 i337(m).. 1. Root your device with any method you like... (cfroot, kingo, etc) 2. Install root explorer 3.0 (or any newer version available) 3. Open root explorer and locate EFS folder (dont forget to mount as R/W) and Delete it (it maybe will say error, just try again) you know it is done when you press power button to turn off (it will power off without select power off option) 4. Repair imei/unlock with spt of course and after that.. wifi will work again... Tested by me.. sent from my sm-n900 using tapatalk |
The Following 4 Users Say Thank You to vickcar13 For This Useful Post: |
03-10-2014, 22:49 | #2 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Where you never imagine Age: 42
Member: 80724 Status: Offline Sonork: 100.1610017 Thanks Meter: 42 | I tried the solution and it is 100% working WiFi, IMEI, calls and everything!!! I already tried on S4 I337. I will try on I337M. Thanks Sir! |
03-20-2014, 13:29 | #5 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2151640 Status: Offline Thanks Meter: 1 | Hey guys, I'm having the same issue on my i337. Could someone explain a few things on the steps of vickcar13 op? I have already installed root explorer and located EFS folder. I don't understand what "(dont forget to mount as R/W)" means. And after that how do I "Repair imei/unlock with spt". Sorry if my questions sound dumb, I am a total newbie... |
The Following User Says Thank You to chanik For This Useful Post: |
05-08-2014, 17:52 | #7 (permalink) | |
Junior Member Join Date: Apr 2014 Location: Toronto, Canada
Member: 2171813 Status: Offline Thanks Meter: 2 | Quote:
im sorry if this sounds too dumb... but after downloading root explore from play store (if thats even how to do install it properly..) how do you mount it as R/W? and what dose that mean? can you tell me if im in the right screen? thanks lots! id like to post a screen shot but forum wont let me post a link... | |
05-10-2014, 00:30 | #8 (permalink) |
Member: 2171813 Status: Offline Thanks Meter: 2 | K... I so i tried to remove EFS... and it shows delete failed ----------------- efs from / and it won't turn off without power off options.. so which step am i missing? PLEASE HELPP!! |
06-04-2014, 03:54 | #12 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Calgary
Member: 1918024 Status: Offline Sonork: 100.1638888 Thanks Meter: 45 | before unlock the S4 SGH-i337M Backup the NVM and Root the phone before Unlock root file "CF-Auto-Root-jfltecan-jfltevl-sghi337m.tat.md5" by odin V3.09 ---------------------------------------------------------------- 1- Select Supported Model From List ( SGH-i337M) 2- Put Your Phone In Download Mode 3- Reset Default EFS In this phase Use USB Cable attach the computer Set your phone to download mode Select correct com port to reset Default EFF If every thing OK, Your phone should reboot by itself ------------------------------------------------------------------------- 4- Select Comport Use UART Cable 5- Select Repair IMEI + UNLOCK 6- Type correct IMEI 7- Do Factory Mode In this phase you should set phone in normal mode Use UART Cable attach to the SPT box Use device manager to decide which port to select If ever thing OK, Your phone should be factory reset by itself if get time out error keep phone connect to the box reboot after reboot, wait the phone fully boot up type *#06#, the IMEI should show 00 or Null that is good sign, then click factory mode ------------------------------------------------------------------------- Write back NVM file Remove Root Last edited by jason557; 06-04-2014 at 04:02. |
06-11-2014, 00:37 | #13 (permalink) | |
Junior Member Join Date: May 2014
Member: 2185502 Status: Offline Thanks Meter: 3 | Quote:
The Following User Says Thank You to tofast420 For This Useful Post: |
07-02-2014, 21:12 | #15 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Corral de Bustos, Argentina
Member: 578880 Status: Offline Thanks Meter: 144 | Try make one "reset efs" then Unlock/Super Imei and again Unlock/Super Imei. Remember 1 Reset - 2 unlock/imei WIFI problem solved Tested in N900 Note 3 Movistar Argentina nikita3000 |
