12-18-2019, 20:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: 408 ikwerre road rumuokwuta
Member: 1994486 Status: Offline Thanks Meter: 3 | Samsung G610f custom binary blocked by frp |
12-18-2019, 20:48 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
What firmware and binary have you installed on your phone? If you can't reset frp with z3x and you have an octopus box with the installed combination, use the emmc method via uart cable and reset frp, do a factory reset, restart the phone and flash the stock firmware in 4 files Last edited by amleto90; 12-18-2019 at 20:54. | |
12-18-2019, 21:39 | #4 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | the custom binary blocked by frp is always active frp only that the phone does not enter recovery mode, if you try to make the flash drl normal firmware you always get stuck you have to bypass frp, I read that you do not want to delete the phone data but you have no other solution unless you have already tried to flash the stock firmware but I doubt that the phone will restart in normal mode without erasing the data there are many forum posts that explain how to bypass custom binary blocked by frp, the only way you have is to reset frp to restart the phone try to follow the guide of this video even if it is not the g610f model to bypass custom binary blocked by frp without deleting the data https://www.youtube.com/watch?v=TSYIC1JBGMY&app=desktop Last edited by amleto90; 12-18-2019 at 21:45. |
