04-12-2021, 09:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Tunisia
Member: 411207 Status: Offline Thanks Meter: 164 | A125F black screen after write firmware [Answered] i get A125F WITH FRP LOCK NOT WORK WITH ANY SOLUTION itry to downgrade with A125FXXU1ATKC but now phone work with black screen. nb lcd not change is original.how get correct file Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A125F Software version: 42.10 File analysis... OK Total file size: 0x162D7679F (5677 Mb) Searching USB Flash interface... COM28 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending preloader.img.lz4... OK Sending lk-verified.img.lz4... OK Sending param.bin.lz4... OK Sending up_param.bin.lz4... OK Sending vbmeta.img.lz4... OK Sending efuse.img.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending dtbo.img.lz4... OK Sending super.img.lz4... OK Sending userdata.img.lz4... OK Sending md_udc.img.lz4... OK Sending scp-verified.img.lz4... OK Sending spmfw-verified.img.lz4... OK Sending sspm-verified.img.lz4... OK Sending tee-verified.img.lz4... OK Sending tzar.img.lz4... OK Sending vbmeta.img.lz4... OK Sending vbmeta_samsung.img.lz4... OK Sending md1img.img.lz4... OK Sending cache.img.lz4... OK Sending omr.img.lz4... OK Sending prism.img.lz4... OK Sending optics.img.lz4... OK Flashing done (time - 00:03:47) Done with Samsung Tool PRO v.42.10 |
04-12-2021, 09:37 | #2 (permalink) |
Member: 411207 Status: Offline Thanks Meter: 164 | here info Code: BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select diagnostic port in port settings. 5. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Info Selected model: SM-A125F Software version: 42.10 Searching Samsung modem... detected COM41 Reading phone info... Model: SM-A125F AP version: A125FXXU1ATKC CSC version: A125FOJM1ATKC CP version: A125FXXU1ATKC Product code: XSG Phone SN: R58R30RYW2R IMEI: 352998440523297 IMEI2: 353856710523299 Unique number: CR8100E9A530818 Reading IMEI... error (1) Done with Samsung Tool PRO v.42.10 |
04-12-2021, 09:44 | #3 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,042 | Download and flash another firmwares untill screen start working. Or if you read info before flashing you can try this firmware first. |
The Following User Says Thank You to Z3X For This Useful Post: |
07-26-2021, 07:24 | #13 (permalink) | |
Junior Member Join Date: Feb 2011 Location: Pakistan
Member: 1525038 Status: Offline Sonork: Danigee Thanks Meter: 12 | Quote:
https://androidfilehost.com/?fid=2188818919693781130 | |
The Following 6 Users Say Thank You to luqmangee For This Useful Post: |
10-12-2021, 16:26 | #14 (permalink) |
Junior Member Join Date: Oct 2020 Location: iraq Age: 22
Member: 2971186 Status: Offline Thanks Meter: 3 | my solution if your phone in this build A125FXXU1BUG6 and you flash with u1 security and android 10 same as A125FOLM1ATKC_XXV or A125FOLM1ATKC_XID the phone com in black screen mode. so i flash this build (MID_A125FXXU1AUB4) and its work and also frp bypass will be done. |
The Following 2 Users Say Thank You to _kernel For This Useful Post: |
