02-10-2016, 01:35 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Paraguay
Member: 1110740 Status: Offline Thanks Meter: 383 | N910C security damage REAL SOLUTION 100% if you got the N910c with SECURITY DAMAGE problem, and cant write cert because of that just select MODEL N900A write cert of N910C Operation: Write CERT Selected model: SM-N900A Selected port: COM5 USB Serial Port Software version: 22.7 Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 4.4.4 Product code: Phone version: N910CXXU1ANJ4 PDA version: N910CXXU1ANJ4 CSC version: N910CTFG1ANJ4 CSC country code: OPEN CSC sales code: TFG HW version: Phone S/N: Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK voila! thats work good, after try hundreds of solutions sugested thats the one who really works. if you find this usefull, please hit THANKS button |
The Following 65 Users Say Thank You to abrapy For This Useful Post: |
03-05-2016, 17:35 | #4 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | need wipe efs first then do it thanks man graet work ============== Operation: Write CERT Selected model: SM-N900A Selected port: COM6 Z3X BOX Serial Port Software version: 24.6 Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.1.1 Product code: Phone version: N910CXXU1COI4 PDA version: N910CXXU1COI4 CSC version: N910COJV1COI1 CSC country code: KSA CSC sales code: KSA HW version: Phone S/N: Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.24.6 |
The Following 4 Users Say Thank You to chand_gee For This Useful Post: |
04-23-2016, 09:09 | #6 (permalink) |
Freak Poster Join Date: May 2015
Member: 2399952 Status: Offline Thanks Meter: 40 | its working .............. BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N900A Selected port: Software version: 25.1 Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.1.1 Product code: Phone version: N910CXXU1COJ5 PDA version: N910CXXU2COJ5 CSC version: N910COJV2COK1 CSC country code: South Africa CSC sales code: XFM HW version: Phone S/N: Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.25.1 |
07-16-2016, 09:19 | #7 (permalink) |
Freak Poster Join Date: Feb 2010 Location: sharjha
Member: 1236922 Status: Offline Sonork: sajer007 Thanks Meter: 101 | Checking certificate file... OK KEY ID: 0065 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: Phone version: N910CXXU1DPE3 PDA version: N910CXXU2DPFA CSC version: N910COLB2DPE3 CSC country code: THAILAND CSC sales code: THL HW version: Phone S/N: 00000000000 Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Checking Super user right... true Reading nv data... OK Analisis NV data... error Security damaged Done with Samsung Tool PRO v.25.1 |
The Following User Says Thank You to sajer007 For This Useful Post: |
08-16-2016, 15:11 | #10 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAŅA
Member: 808967 Status: Offline Thanks Meter: 155 | Operation: Write CERT Selected model: SM-N910C Software version: 26.2 Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 4.4.4 Product code: Phone version: N910CXXU1ANK5 PDA version: N910CXXU1ANK5 CSC version: N910COXX1ANK2 CSC country code: SEAD CSC sales code: SEE HW version: Phone S/N: RF8G20FTDQE Modem board: DB7450R RF cal date: 1234.56.78 IMEI: 356769060053469 Checking Super user right... true Reading nv data... OK Analisis NV data... OK Writing nv data... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 4.4.4 Product code: Phone version: N910CXXU1ANK5 PDA version: N910CXXU1ANK5 CSC version: N910COXX1ANK2 CSC country code: SEAD CSC sales code: SEE HW version: Phone S/N: RF8G20FTDQE Modem board: DB7450R RF cal date: 1234.56.78 IMEI: 356769060053469 Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.26.2 |
09-10-2016, 12:04 | #12 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: 90-region Age: 39
Member: 1246378 Status: Offline Thanks Meter: 123 | Quote:
09-20-2016, 10:04 | #14 (permalink) |
Junior Member Join Date: Jun 2016 Location: uzbekistan
Member: 2580421 Status: Offline Thanks Meter: 3 | Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 5.1.1 Product code: Phone version: N910CXXU1COJ5 PDA version: N910CXXU2COJ5 CSC version: N910COXE2COJ1 CSC country code: Central Asia CSC sales code: CAC HW version: Phone S/N: Modem board: DB7450R RF cal date: 1234.56.78 IMEI: Initialization AT RIL... OK OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.26.7 Thanks |
The Following User Says Thank You to Azamxoja For This Useful Post: |
09-25-2016, 17:33 | #15 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1104609 Status: Offline Thanks Meter: 1 | Operation: Write CERT Selected model: SM-N910H Software version: 26.7 Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910H Android version: 6.0.1 Product code: SM-N910HZKEXFE Phone version: N910HXXU1DPC1 PDA version: N910HXXS2DPH2 CSC version: N910HOXE2DPE1 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.800 Phone S/N: R21G3199YKE Modem board: DB7450R RF cal date: 2015.03.09 IMEI: Checking Super user right... true Reading nv data... OK Analyzing NV data... OK Writing nv data... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SM-N910H Android version: 6.0.1 Product code: SM-N910HZKEXFE Phone version: N910HXXU1DPC1 PDA version: N910HXXS2DPH2 CSC version: N910HOXE2DPE1 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.800 Phone S/N: R21G3199YKE Modem board: DB7450R RF cal date: 2015.03.09 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.26.7 |
The Following User Says Thank You to mrisvan For This Useful Post: |
