01-27-2021, 12:37 | #1 (permalink) |
Freak Poster Join Date: Mar 2016
Member: 2542848 Status: Offline Thanks Meter: 80 | A205F flash failed [Answered] 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A205F Software version: 42.0 File analysis... OK Total file size: 0x15C3A43AD (5571 Mb) Searching USB Flash interface... COM3 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending cm.bin.lz4... OK Sending vbmeta.img.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending dt.img.lz4... OK Sending dtbo.img.lz4... error timeout Done with Samsung Tool PRO v.42.0 |
