10-02-2021, 08:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | A217F can't read nck codes.pls help,. [Answered] To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-A217F Software version: 43.16 Checking Login and Password... OK Balance: 8 crd. You have 8 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A217F Android version: 10 PDA version: A217FXXU5BUA2 CSC version: A217FOLM5BUA2 Phone version: A217FXXU5BUA2 Product code: SM-A217FZWGXME CSC country code: MALAYSIA CSC sales code: XME Carrier ID: KSA Phone SN: RF8R400A38M IMEI: 357469632129090 HW version: MP 0.500 RF cal date: 20210401 Chip name: EXYNOS850 Modem board: SHANNON318 Security patch: 2021-01-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading lock state... OK Checking SIM status... OK Executing... OK Searching Ramdump interface... COM9 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... OK Now only the MCK(Freeze) code will be calculated. Continue? No To calculate NCK(Network) code perfom the following operations: 1. Insert the SIM card. 2. Enter the MCK(Freeze) code. 3. Remove the SIM card. 4. Reboot phone. 5. Try again. If you don't have the MCK(Freeze) code, then read it first. Done with Samsung Tool PRO v.43.16 UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-A217F Software version: 43.16 Checking Login and Password... could not connect to server Checking Login and Password... OK Balance: 8 crd. You have 8 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A217F Android version: 10 PDA version: A217FXXU5BUA2 CSC version: A217FOLM5BUA2 Phone version: A217FXXU5BUA2 Product code: SM-A217FZWGXME CSC country code: MALAYSIA CSC sales code: XME Carrier ID: KSA Phone SN: RF8R400A38M IMEI: 357469632129090 HW version: MP 0.500 RF cal date: 20210401 Chip name: EXYNOS850 Modem board: SHANNON318 Security patch: 2021-01-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading lock state... OK Checking SIM status... OK Executing... OK Searching Ramdump interface... COM9 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... error (1) Could not find data. Please try again. Done with Samsung Tool PRO v.43.16 many tmimes have tried. all the tricks have done -enter mck, remove sim, reboot -enter mck,remove -hard reset, enter mck, remove sim, reboot -hardreset, enter mck,remove sim all failed,. my acct: zsc_4kIhuHL8 may i request to refund my 5cr then i will root it instead of trying so many hours,. i already have mck but its useless without nck. please help team,. just need to refund then i will root it for unlock,. thanks again,. |
