>>> A510F can't flash after Combination file <<< Hi, mates. I had to reset the FRP of this Samsung A510F, so I first flash it with COMBINATION_FAC_FA51_A510FXXU3API1, then "Rest FRP" with Z3X, but now, when I try to flash it with "normal" rom (from the support area) , so I can revive the set, Z3X gives me this error: Code: File analysis... OK I tried different firmwares, but always end up with this error... Any ideas, mates? |
have u try to flash the set with Smart Switch ? |
Yep, I did, mate. Smart Switch tells me that this model is not supported :( |
And I can't flash it neither with 6.0.1, nor with 5.1.1... How to revive it?! |
Get the kies and install with kies frp is not leting you flash Sent from my iPhone using Tapatalk |
@igma, I tried with Kies, but no luck - again this SYSTEM REV. CHECK FAIL DEVICE: 3, BINARY: 2 Any other ideas? Support team? Anybody?! Why can't I flash the phone after this combination file?! FRP IS NOT DONE and now I can't even revive the set!? Wtf?! |
Use Odin mate+Full FW. Br, xerraco |
@xerraco, I did, mate, but It's the same situation - SYSTEM REV. CHECK FAIL DEVICE: 3, BINARY: 2 . The set just can't be flashed anymore. Im running out of ideas, that's why Im asking here how return to original/alive state. The only thing that the phone accepts, without any errors during flash, is this COMBINATION_FAC_FA51_A510FXXU3API1 file. Nothing else! |
Hi. What does it mean "normal" flash for You? More details please. Have U tried with A510FXXU3BPIB? http://www.**************/firmwares/...FTEF3BPI5_O2U/ This error looks like U want do downgrade. |
yes ı have the seam problem In my a510f pls can you help me |
Try to flash unselecting "sboot.bin" and "cm.bin" partitions. Acording logs you want to downgrade, so try to flash all other partitions except that two. |
ok can you show me how pls can you gıve me the lınk for the fıls and tell how to do ıt |
I have Same Problem In J700F I am Trying To Flash Original Firmware And It Gives Error "Custom Binary Blocked By FRP " Usually it comes in read color but in my case showing In Green Color... I used latest firmware 6.0.1 i used lollipop firmware i used combination firmware i tried single single partition.. |
Ok, mates, I did it - I managed to revive this A510F with A510FXXU3BPIB_A510FTEF3BPI5. I had some issues though - the flash process again stops (without those red lines, that indicates downgrading), but this time at hidden.img..., so I had to remove this part from the flash file and voila - everything was fine. The phone is alive now. @souloxo, you can find yours here https://samsung-firmware.org/model/SM-A510F/page/1 |
thnx pro i thnx you but can you give me a free rom without buying ?? |
