11-04-2015, 10:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Online Thanks Meter: 2,283 | E1205y read code done UNLOCK INSTRUCTIONS: Flash mode: COM Port does not matter, phone will be detect automatically. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. 2. Connect phone in flash mode (Press 'OK' button (Centre of navigation buttons module) and connect USB cable). Normal mode: 1. Connect powered on phone to USB, choose correct COM port in port settings. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: GT-E1205Y Selected port: COM4 Z3X BOX Serial Port Software version: 23.2 Waiting phone... detected COM68 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Checking NV... OK IMEI Master: 359468068527916 Phone HW: MP 0.400 Product code: GT-E1205ZWYXFV Phone S/N: R21G42KP4B Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 04260515 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.2 |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
11-04-2015, 14:36 | #2 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | E1205Y read info Codes ERROR Aslamualikum Sir , thanks for sharing your experience , i am trying also with E1205Y , BUT phones DEAD after UNLOCK, but now i am using Read Codes button, i just want to ask question that which cable you are using ? J750 or SAM E210 ( 2 in 1 ) ??? because when i use 2 in one cable Z3X box detect SciCmpst Diag Port |
11-04-2015, 14:59 | #3 (permalink) | |
Member: 328688 Status: Online Thanks Meter: 2,283 | Quote:
u need hole Centre of navigation button put cable inside then battery u will get right | |
11-13-2015, 19:30 | #9 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1961725 Status: Offline Sonork: 100.1640687 Thanks Meter: 6 | UNLOCK INSTRUCTIONS: Flash mode: COM Port does not matter, phone will be detect automatically. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. 2. Connect phone in flash mode (Press 'OK' button (Centre of navigation buttons module) and connect USB cable). Normal mode: 1. Connect powered on phone to USB, choose correct COM port in port settings. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: GT-E1205Y Selected port: COM16 SciCmpst Diag Software version: 23.3 Reading phone info... OK IMEI Master: --------------- Product code: GT-E1205ZKYEGY Phone HW: MP 0.400 Phone S/N: ------- Reading codes... OK Please wait, calculating codes... OK (time - 00:01:14) Freeze code: 96275742 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.3 |
07-20-2016, 16:34 | #10 (permalink) |
Junior Member Join Date: Oct 2015 Location: Namibia Age: 33
Member: 2475472 Status: Offline Sonork: DONIX Thanks Meter: 2 | Good day Please help I have a Samsung GT-E1205Y with a sim lock I try to conect with Samsung tool Pro 26 but it doesn't want to detect the phone i also try and press the OKAY button but doesn't want detect phone at all please tell me how make so that i can detect the phone or must i remove the battery or what? |
