07-02-2009, 12:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | KU 990iG Is this model supports for unlock? |
07-02-2009, 15:02 | #2 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | 1. Check manual model select. 2. Select Ku990i 3. Select Ku990i firmware. 4. Flash phone. 5. Unlock phone. 6. Done. |
The Following 2 Users Say Thank You to andrew_tm For This Useful Post: |
07-07-2009, 09:21 | #3 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | v.1.5.4 supported models: 61 andrew_tm 2009(c) Mode: Normal Model: KU990iG Build version: Mar 21 200915:44:45FEB 25 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10a-FEB-25-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 1 secs. Mode: Normal Model: KU990iG Build version: Mar 21 200915:44:45FEB 25 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10a-FEB-25-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 0 secs. This phone are not supported! When I flash with KU990i flash file it was stoped when the media file is writting it was stoped in 50 percent written.I already tried three times.Now what can do?Its urgent.Solution please. Here is the log: v.1.5.4 supported models: 61 andrew_tm 2009(c) Mode: Normal Model: KU990iG Build version: Mar 21 200915:44:45FEB 25 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10a-FEB-25-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 1 secs. Mode: Normal Model: KU990iG Build version: Mar 21 200915:44:45FEB 25 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10a-FEB-25-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 0 secs. This phone are not supported! Reading file as KU990i... Ok Original Firmware file: KU990i-DZ-V10b-MAR-12-2009-OPN-EU Mode: Normal Model: KU990iG Build version: Mar 21 200915:44:45FEB 25 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10a-FEB-25-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 1 secs. NV read... NV save:..\backup\KU990i_354693031417441_07072009_114 939.cnv Elapsed: 82 secs. Start Flash... Modem Write Start... Write Block: 2 address: 0x019A4000 Modem file flash error! Elapsed: 325 secs. |
07-07-2009, 10:33 | #4 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | After some triles I restarted my system and try at once.After the system restart my problem is solved.Thanks to Andrew_tm and Z3X Team. Here is the log: v.1.5.4 supported models: 61 andrew_tm 2009(c) Mode: Normal Model: KU990i Build version: Apr 01 200917:30:11FEB 13 200917:00:00KU990i SW Version: KU990i-MSM6280-V10a-FEB-25-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 0 secs. Reading file as KU990i... Ok Original Firmware file: KU990i-DZ-V10b-MAR-12-2009-OPN-EU Mode: Normal Model: KU990i Build version: Apr 01 200917:30:11FEB 13 200917:00:00KU990i SW Version: KU990i-MSM6280-V10a-FEB-25-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 0 secs. NV read... NV save:..\backup\KU990i_354693031417441_07072009_135 620.cnv Elapsed: 66 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 2539 secs. Mode: Normal Model: KU990i Build version: Mar 31 200920:23:46FEB 13 200917:00:00KU990i SW Version: KU990i-MSM6280-V10b-MAR-12-2009-XX IMEI: 35469303141744-1 BlueTooth Address: 00:22:A9:97:FD:52 Elapsed: 0 secs. Firmware signature in base: 130 Ver: Mar 31 200920:23:46FEB 13 200917:00:00KU990i Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\KU990i_354693031417441_070 72009_144222.sec Erase sec. zone... Write data to phone... write page: 00000BC0 write page: 00000BC1 write page: 00000BC2 write page: 00000BC3 write page: 00000BC4 write page: 00000BC5 Phone rebooted! Elapsed: 10 secs. Now My phone is successfully unlocked.Thanks. |
12-02-2011, 23:58 | #5 (permalink) |
Insane Poster Join Date: Dec 2004 Age: 61
Member: 95043 Status: Offline Thanks Meter: 0 | I have a similar problem. Phone is KU990iG but on sticker KU990I Flashed it with KU990i Firmware and got the yellow screen with "refreshing" Flashed it again with the above Fw (10b MAR -12-2009) and now I've got "OTP block unavailable". Please can you explain how to properly flash the KU990iG to work again? |
12-03-2011, 00:05 | #6 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | 1. Download LG qualcomm tool 2.0.7 from support area. 2. select in LG Qualcomm tool 2.0.7 KC910 in model list and check in options: manual model select. 3. Press unlock button and in dialog window selec New Algo restore from backup. 4. Select first time backup your KU990iG. 5. After restore phone must work but locked. 6. Select in model list ku990 , check in options manual model select and press unlock. 7. Done. -- |
BB 9520 and 9550 storm2, is this model supported for unlock or not... [SOLVED] | nelsky | 3GKey / BB-Box | 3 | 01-30-2010 02:11 |
LG 410GB is this unit supported for unlocking..!!! | newfoundghori | VygisToolbox | 4 | 01-04-2010 10:35 |
Is this Models Supported mx key for unlock? | caremobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 09-01-2009 04:47 |
5800d is this model Supports for unlock? | caremobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-20-2009 08:20 |
T-303 is this model supports for unlock with supreme credits? | caremobiles | D-Unlock Suite | 2 | 06-26-2009 05:26 |
