09-02-2010, 12:49 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | with broadcom Flasher .. here is Log * How to use Download Mode 1. Turn off the target phone!!! 2. Select COM Port(USB or UART) , Baud Rate. 3. Push the Start Button. 4. Turn on the target phone!!! * Connecting to target phone Try to open COM1 >Success!! - Turn on the target phone immediately!!!! Listen for the BOOT signal > > > OK Send the Download start signal > > > OK Listen for the Download start ACK signal > > > OK * NAND Flash Driver Download preloader downloading > > > OK NAND Flash driver downloading > > > OK Flash Type Checking > > > OK NAND Bad block check > > > 128 Bad block found --------------------------------------------------------- P.Block[65287] ---> S.Block[38677] P.Block[15797] ---> S.Block[20054] P.Block[39987] ---> S.Block[8914] P.Block[34438] ---> S.Block[62610] P.Block[32886] ---> S.Block[39404] P.Block[59652] ---> S.Block[7451] P.Block[8902] ---> S.Block[15713] P.Block[65311] ---> S.Block[31696] P.Block[14126] ---> S.Block[64550] P.Block[53283] ---> S.Block[4493] P.Block[56646] ---> S.Block[48534] P.Block[64110] ---> S.Block[34881] P.Block[4265] ---> S.Block[9677] P.Block[2901] ---> S.Block[10214] P.Block[36823] ---> S.Block[47300] P.Block[40894] ---> S.Block[50485] P.Block[1513] ---> S.Block[62308] P.Block[26143] ---> S.Block[52975] P.Block[40262] ---> S.Block[30919] P.Block[15830] ---> S.Block[21997] P.Block[59326] ---> S.Block[52188] P.Block[10668] ---> S.Block[20405] P.Block[11619] ---> S.Block[55968] P.Block[53965] ---> S.Block[54585] P.Block[48198] ---> S.Block[3156] P.Block[25787] ---> S.Block[16767] P.Block[20301] ---> S.Block[5726] P.Block[20852] ---> S.Block[60889] P.Block[8083] ---> S.Block[59287] P.Block[61694] ---> S.Block[39942] P.Block[19326] ---> S.Block[56814] P.Block[18846] ---> S.Block[64358] P.Block[12242] ---> S.Block[32481] P.Block[65005] ---> S.Block[34690] P.Block[5083] ---> S.Block[44119] P.Block[20381] ---> S.Block[18794] P.Block[63002] ---> S.Block[14143] P.Block[9828] ---> S.Block[4671] P.Block[5088] ---> S.Block[60832] P.Block[36216] ---> S.Block[51063] P.Block[30251] ---> S.Block[45293] P.Block[28221] ---> S.Block[54319] P.Block[43878] ---> S.Block[446] P.Block[39597] ---> S.Block[21114] P.Block[59654] ---> S.Block[29357] P.Block[44282] ---> S.Block[8676] P.Block[58004] ---> S.Block[7747] P.Block[59746] ---> S.Block[40675] P.Block[62802] ---> S.Block[64334] P.Block[30508] ---> S.Block[62285] P.Block[33298] ---> S.Block[36710] P.Block[33613] ---> S.Block[14696] P.Block[43361] ---> S.Block[42306] P.Block[17876] ---> S.Block[4082] P.Block[5520] ---> S.Block[34755] P.Block[47040] ---> S.Block[41787] P.Block[25773] ---> S.Block[30571] P.Block[16101] ---> S.Block[28426] P.Block[64533] ---> S.Block[21070] P.Block[30263] ---> S.Block[15119] P.Block[46335] ---> S.Block[10573] P.Block[39823] ---> S.Block[61531] P.Block[56970] ---> S.Block[6833] P.Block[20347] ---> S.Block[64899] P.Block[41980] ---> S.Block[52886] P.Block[63045] ---> S.Block[64603] P.Block[42514] ---> S.Block[29863] P.Block[41055] ---> S.Block[64897] P.Block[15949] ---> S.Block[23982] P.Block[32007] ---> S.Block[59109] P.Block[13886] ---> S.Block[12986] P.Block[61722] ---> S.Block[38699] P.Block[3989] ---> S.Block[58087] P.Block[55831] ---> S.Block[15028] P.Block[62262] ---> S.Block[31722] P.Block[18235] ---> S.Block[3939] P.Block[35613] ---> S.Block[32979] P.Block[53828] ---> S.Block[4597] P.Block[19404] ---> S.Block[43313] P.Block[60879] ---> S.Block[48881] P.Block[58865] ---> S.Block[52315] P.Block[49993] ---> S.Block[53049] P.Block[50663] ---> S.Block[30632] P.Block[53230] ---> S.Block[15803] P.Block[52207] ---> S.Block[16477] P.Block[33747] ---> S.Block[45131] P.Block[12352] ---> S.Block[14193] P.Block[38243] ---> S.Block[35703] P.Block[56641] ---> S.Block[16981] P.Block[13614] ---> S.Block[25736] P.Block[17218] ---> S.Block[54063] P.Block[54802] ---> S.Block[65450] P.Block[26047] ---> S.Block[63289] P.Block[49152] ---> S.Block[28555] P.Block[43390] ---> S.Block[51593] P.Block[12141] ---> S.Block[32729] P.Block[39083] ---> S.Block[40199] P.Block[34739] ---> S.Block[34554] P.Block[47440] ---> S.Block[42759] P.Block[5459] ---> S.Block[28482] P.Block[4980] ---> S.Block[4778] P.Block[30746] ---> S.Block[30290] P.Block[50474] ---> S.Block[65198] P.Block[25701] ---> S.Block[20508] P.Block[59105] ---> S.Block[33979] P.Block[19510] ---> S.Block[13418] P.Block[39909] ---> S.Block[65005] P.Block[21293] ---> S.Block[50426] P.Block[34395] ---> S.Block[52185] P.Block[33875] ---> S.Block[9818] P.Block[43620] ---> S.Block[8131] P.Block[12902] ---> S.Block[3891] P.Block[43438] ---> S.Block[58847] P.Block[32381] ---> S.Block[56344] P.Block[26710] ---> S.Block[60354] P.Block[60346] ---> S.Block[47461] P.Block[43622] ---> S.Block[58121] P.Block[52251] ---> S.Block[57154] P.Block[60057] ---> S.Block[61025] P.Block[46429] ---> S.Block[61367] P.Block[27827] ---> S.Block[32671] P.Block[39341] ---> S.Block[8724] P.Block[31251] ---> S.Block[12667] P.Block[63125] ---> S.Block[34219] P.Block[44859] ---> S.Block[42686] P.Block[42102] ---> S.Block[9689] P.Block[32420] ---> S.Block[26701] P.Block[27515] ---> S.Block[30358] --------------------------------------------------------- OK UART Download Mode > > > Available * NAND Flash Erase Nand Flash Erasing > > > OK Now Bootloader erased * NAND : Preboot Download Preboot Download start!! ----------------------------------------------------------------------------------------------- Address 0x00000000... just stucked there .... |
09-02-2010, 12:56 | #3 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | on Z3x When i click Boot Button , bar below starts moving ... then i Insert battery , Bar below Stops .. then i get this error ... Connect phone to special micro-uart cable Start repair boot zone type 2... Timeout Repair boot - false Elapsed time: 30 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
8810 pinout?? | timitiz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-11-2012 11:10 |
Please Help, Pinout of N8810 | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-30-2010 15:53 |
8810 pinouts for dejan flasher !?!?!? | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-03-2001 04:39 |
8850 pinouts | MDR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-30-2000 01:23 |
