bom bom G920T PH2 UNLOCK DONE BOM BOM UPDATE T MOBILE G920T 6.0.1 UNLOCK DONE FEEL POWER Z3X :D:D:D https://s21.postimg.org/iga8egzxz/Ne...ap_Image_3.jpg |
G920t ph2 Have you tried to patch Cert file ???? REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G920T Software version: 26.8 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 6.0.1 Product code: SM-G920TZKATMB Phone version: G920TUVS4EPH2 PDA version: G920TUVS4EPH2 CSC version: G920TTMB4EPH2 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58G31EA5DR Modem board: SHANNON333 RF cal date: 20150319 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.26.8 |
bro everything is ok my phone work good ...you need cert ?? z3x not support red cert 6.0.1 whan you try to red cert show error 9 must need sboot downgrade ....im jest done unlock |
says sucessful on mine but still not unlocked |
how did you root it ? i dont need twrp anything other than that?? |
im root by chimera tools unlok by z3x .... |
thanks. . |
not working for me, keeps saying the phone is locked g920t 6.0.1 ph2 |
CHIMERA DID NOT WORK Chimera Mobile Phone Utility version: 12.08.1138 @ 2016-11-21 Printing phone history Root/Unroot 11/21/2016 6:52:58 PM [Rooting phone started] Checking custom root image... This model is not available custom root image. Unable to root. Retry or root manually. Click here to download rooting tools. Finished at local time: [11.21.16 13:54:26] WorkID: 1XXXXXXXXX BUT CF AUTO R... WORKS.....! PD6 FOR PH2 USE IT ON YOUR OWN RISK . THANKS |
