c3050 problem to flash i have 3 phone c3050 whith same probleme don't show numper or menu so, i flash this tree phone with lotof version from suport but i have same probleme this is the log flash Selected model: C3050 Selected com port: COM3 Selected speed port: 460800 Decode *.s3 file - please wait segments 9 segment 1 20000000 100 byte segment 2 20300000 23964560 byte segment 3 2001E000 180 byte segment 4 20016000 26012 byte segment 5 20078000 1132368 byte segment 6 2000C000 21404 byte segment 7 20058000 56 byte segment 8 20058138 16924 byte segment 9 2003803C 36508 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 890000007E88 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 199 Format FFS - wait... OK Send content - wait... bad ask - +ok! Send cts - fail Elapsed time: 1039 second, sw ver: 3.5.0029 --------------------------------------------------------- |
same problem..after flash and reflash another csc and code file problem remaining.. |
same problem. after language changing not menu bar, not numbers, just sounds. i tried 20-30 files. not match combination. any idea? |
if i read the eeprom and the flash from the other good phone, can work with these files? |
i read a good flash from another phone. i write it in this phone. the phone is ok now, have menu, all works except good imei. imei is from good phone and if i type *#06# on display is 00000000000000. i try to repair the imei but not result. no imei, no network, no unlock. any idea? |
solved i write the firmware located in C:\Program Files\Z3X\Samsung\SamsungTool\C3050_RU8B201431T_.s re. all work ok now, after direct unlock. if u need C3050 good flash ask me on yahoo messenger: geogsm |
