10-05-2016, 14:10 | #1 (permalink) |
Freak Poster Join Date: May 2016 Location: Sidi Yahia du Gharb
Member: 2577035 Status: Offline Thanks Meter: 13 | Can't remove FRP Lock from J500FN Selected model: SM-J500FN Selected port: Software version: 26.9 Searching Samsung USB Flash interface... COM35 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.26.9 |
10-18-2016, 02:24 | #2 (permalink) |
Junior Member Join Date: Oct 2016 Location: GPS Failed...
Member: 2632572 Status: Offline Sonork: 404 Not Found Thanks Meter: 1 | Try this method, it worked for me: 1) Flash COMBINATION_OXA_FA51_J500FNXXU1APA1_OXA1APA1 2) Don't let the phone reboot (Remove the battery) 3) Enter "Download Mode" and hit "Reset FRP/React/EE" button 4) Let the phone restart 5) Wipe data from recovery 6) You can unlock network if needed 7) Flash with original firmware 8) You're all done |
The Following User Says Thank You to BuLLHACK For This Useful Post: |
11-13-2016, 19:48 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | You dont need a combo file for that model...just extract sboot from J500FNXXU1AOJ2 rom and flash it then put into download and wipe frp. After you are done flash any J500FN 6.0.1 sboot You think you would learn after over a year. |
11-16-2016, 23:32 | #10 (permalink) |
Freak Poster Join Date: Nov 2011 Location: france
Member: 1690056 Status: Offline Thanks Meter: 103 | salem Searching Samsung USB Flash interface... COM4 detected Setup connection... ok Reading PIT from phone... ok Searching FRP lock... ok Erasing FRP... ok Searching Reactivation lock... not supported Searching EE lock... ok Erasing EE lock... ok Reset done Done with Samsung Tool PRO v.27.1 |
