03-09-2023, 09:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | how i unlock this it ask code To unlock using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock SPR via Server NEW' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Info Selected model: SM-G988U Software version: 45.5 Searching Samsung modem... detected COM39 Reading phone info... Model: SM-G988U AP version: G988USQU2DUJ6 CSC version: G988UOYN2DUJ6 CP version: G988USQU2DUJ6 OS version: 11 Product code: ATT Phone SN: R3CN6020D3J IMEI: 354084114482348 Unique number: CE032043823BD9F81F7E Reading IMEI... OK IMEI: 354084114482348 Done with Samsung Tool PRO v.45.5 [SM-G988U,Info] |
03-09-2023, 12:42 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,063 | Hello. This one not supported atm. Use checkphones: https://z3x-team.com/check-your-phone/ |
03-09-2023, 12:43 | #3 (permalink) |
