05-26-2010, 19:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: pondicherry Age: 38
Member: 687128 Status: Offline Thanks Meter: 261 | e1080f sim lock unlock the phone and *2767*3855# reset same problem how to solve problem |
The Following User Says Thank You to billa2008 For This Useful Post: |
05-27-2010, 07:34 | #3 (permalink) |
Member: 687128 Status: Offline Thanks Meter: 261 | Last version on support: 2G tools v3.4.0046 Selected model: E1080 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Phone IMEI -> 00000000000000 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> Read Info - ok Elapsed time: 22 second, sw ver: 3.4.0046 ------------------------------------------------------------------------------- Selected model: E1080 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 43 second, sw ver: 3.4.0046 ------------------------------------------------------------------------------- |
05-27-2010, 07:39 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,562 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
05-27-2010, 10:15 | #5 (permalink) |
Member: 687128 Status: Offline Thanks Meter: 261 | If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# how to mr.blang unlock the phone and *2767*3855# reset same problem how to solve problem |
06-02-2010, 11:16 | #6 (permalink) |
Freak Poster Join Date: Nov 2002 Location: india Age: 50
Member: 17621 Status: Offline Thanks Meter: 23 | For me too also same problem. Here is my log, Last version on support: 2G tools v3.4.0046 Selected model: E1080 Selected com port: COM14 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 41 second, sw ver: 3.4.0046 And my set is asking for simlock password. I have done this step also;If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000#. |
08-20-2010, 13:55 | #7 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 399228 Status: Offline Thanks Meter: 66 | I also face the same problem in E1080F like this, but i solve it. Keep It on E1080T instead of E1080. Use direct unlock instead of read code and baudrate 115200.That's it. Here is the log: Selected model: E1080T Selected com port: COM10 Selected speed port: 115200 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 126 second, sw ver: 3.4.0046 |
The Following 2 Users Say Thank You to amit_varietymob For This Useful Post: |
09-12-2010, 13:39 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | after kill by flash other E1080 then revive it with E1080F l finaly unlock it using E210 RJ45+usb cable.with J750 only fail thank to Z3X you are the best! Selected model: E1080 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Timeout connect phone Send loaders - fail Elapsed time: 42 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- Selected model: E1080 Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Timeout Send loaders - fail Elapsed time: 17 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- Selected model: E1080T Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 51 second, sw ver: 3.4.0066 |
The Following User Says Thank You to denard For This Useful Post: |
09-24-2010, 17:15 | #9 (permalink) |
Freak Poster Join Date: Nov 2009 Location: U.K (leeds)
Member: 1157490 Status: Offline Sonork: 100.1638346 Thanks Meter: 74 | unlock1080i I have done unlock by pressing direct unlock and is working fine there is no need to put unlock code.here are the logs. Selected model: E1080 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 47 second, sw ver: 3.4.0066 |
11-12-2010, 12:47 | #10 (permalink) |
Insane Poster Join Date: May 2008
Member: 776165 Status: Offline Thanks Meter: 14 | pls help, same problem Selected model: E1080 Selected com port: COM5 Selected speed port: 115200 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Phone IMEI -> 00000000000000 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> Read Info - ok Elapsed time: 63 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- Selected model: E1080 Selected com port: COM5 Selected speed port: 115200 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 124 second, sw ver: 3.4.0071 |
12-01-2010, 10:53 | #11 (permalink) | |
Freak Poster Join Date: Jun 2004 Location: Oran, Algeria Age: 45
Member: 67584 Status: Offline Thanks Meter: 13 | Quote:
Sorry. for unlock E1080F, we can use J750 cable, and choose E1080T. not Fail with J750 cable. Only you have to press power button 3 seconds. if less than 3 seconds, then you have error Fail. Good luck! Thank's friend | |
12-19-2011, 09:30 | #14 (permalink) |
Insane Poster Join Date: Oct 2011 Location: BACOLOD CITY
Member: 1673043 Status: Offline Thanks Meter: 11 | Last version on support: 2G tools v3.4.0046 Selected model: E1080 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Phone IMEI -> 00000000000000 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> Read Info - ok Elapsed time: 22 second, sw ver: 3.4.0046 ------------------------------------------------------------------------------- Selected model: E1080 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 43 second, sw ver: 3.4.0046 |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
