05-06-2017, 09:40 | #1 (permalink) |
Junior Member Join Date: May 2017
Member: 2713083 Status: Offline Thanks Meter: 12 | Solution! (SM-G550T1) Custom Binary Blocked By FRP Lock 1 - put the phone in Download mode ( Volume down + Home + Power bottom) 2 - Select SM-G360T1 Model on the phone list 3 - Go to repair tab 4 - Wipe EFS/NVM and bingo Good Luck PS: You don't need to select adb port. Operation: Wipe EFS/NVM Selected model: SM-G360T1 Selected port: COM11 Z3X BOX Serial Port Software version: 28.1 Searching Samsung USB Flash interface... COM9 detected Setup connection... Ok Reading PIT from phone... Ok Wipe NVM done Done with Samsung Tool PRO v.28.1 |
The Following 4 Users Say Thank You to cvunlk For This Useful Post: |
05-07-2017, 05:28 | #2 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1183411 Status: Offline Thanks Meter: 8 | Thanks for your info, FRP Custom blocked happened on all SAMSUNG when you try to root or flash twrp without OEM on. to fix this, just flash a newer stock and then login with gmail or bypass frp if you do not know . br |
05-07-2017, 11:42 | #3 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Why would you perform wipe efs/nvm operation when you don't have backup? This is risky solution and not safe. The best method is boot phone into recovery mode and note down the phone's version Download exact version or higher and flash. You can flash AP file only or load any AP file version with z3x box and select only boot.img option and flash. You will get your phone back and working You can also flash only BL file if you have multiple firmware. You will still get your phone back |
05-09-2017, 21:48 | #7 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Next time, you can as well perform 'read pit' operation and tool will boot your phone to normal after pit read. no need to wipe efs |
The Following 3 Users Say Thank You to Kwesi_Roy_GH For This Useful Post: |
12-05-2017, 07:53 | #11 (permalink) |
Junior Member Join Date: Aug 2016 Location: anand Age: 26
Member: 2608552 Status: Offline Sonork: [email protected] Thanks Meter: 0 | G550T1 flash file not working plzzz helpl need flash file |
01-31-2018, 17:57 | #13 (permalink) |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | First step, flash the correct versión of software...dont update the version, I think U are try to bypass FRP Lock, after that is done...is only the FRP blocking the root file, without the OEM unlock checked |
