11-27-2016, 12:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1886712 Status: Offline Thanks Meter: 53 | N9208 Msl Rest Error Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Reset MSL Selected model: SM-N9208 Software version: 27.1 Searching Samsung modem... detected COM35 Reading phone info... OK Model: SM-N9208 AP version: N9208XXU3BPJ6 CSC version: N9208ODI3BPJ3 CP version: N9208XXU3BPJ3 Product code: SM-N9208ZDUXME Phone SN: RF1D45EJGGR Unique number: 85334F3630474341 Reading IMEI... OK IMEI: 35(SIGN: OK) IMEI 2: 35 (SIGN: OK) Reseting MSL... error (0) Done with Samsung Tool PRO v.27.1 |
