Old 11-17-2019, 08:25   #1 (permalink)
Member: 803622
Thanks Meter: 41
Exception: Access violation at address 00000000 in module 'SamsungToolPRO.exe'.
Please any 1 have idea how to fix this problem PLEASE
Exception: Access violation at address 00000000 in module 'SamsungToolPRO.exe'. Read of address 00000000
Done with Samsung Tool PRO v.38.2
Having problem on my new PC.
Please is there a setting or anything that I can fix this problem.
Need to use Z3X on my new PC
PLEASE ANY EXPERTISE out there THANKS
Old 11-19-2019, 08:22   #2 (permalink)
Member: 803622
Thanks Meter: 41
So any one have this problem
Is there away to fix it
Old 11-19-2019, 14:18   #3 (permalink)
Member: 803622
Thanks Meter: 41
Problem fix
manage to fix the problem my self
Old 11-25-2019, 22:11   #4 (permalink)
Member: 2635974
Thanks Meter: 45
How you fxed?? I have same problem!
Old 11-27-2019, 02:12   #5 (permalink)
Member: 2795081
ayuda help me
Problem fix
como lo solucionaste amigo?
How did you solve it, friend?
Old 12-02-2019, 16:34   #6 (permalink)
Member: 803622
Thanks Meter: 41
To fix this problem just need to install
vcredist_x64
vcredist_x86
Old 12-21-2019, 08:13   #7 (permalink)
Member: 2795081
la unica solucion que enconte fue formatear mi pc y ya esta funcionando a la perfeccion
Old 12-21-2019, 10:30   #8 (permalink)
Member: 129817
Thanks Meter: 19
same problem
how to fix ?
thanks
The Following User Says Thank You to tikal For This Useful Post:
Old 12-21-2019, 15:28   #9 (permalink)
Member: 1486828
Sonork: pcs1234
Thanks Meter: 53
UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the sof
same problem, installed the 2 files, still same...how to resolve please....
New Securiry Type:
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
6. Press 'Read codes' button and select 'Read codes New' to read security codes.
Old Securiry Type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
5. Press 'Read codes' button and select 'Read codes' to read security codes.
To read security codes via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To read security codes using sever:
5. Press 'Read Codes via server' button, select 'Read codes ...' algo,
write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Read Codes via Server
Selected model: SM-G925F
Software version: 38.11
Checking Login and Password... OK
Ballance: 20 crd.
You have 20 credit(s) left. This operation takes 0 credits.Continue? Yes
Done with Samsung Tool PRO v.38.11
The Following User Says Thank You to pcs1234 For This Useful Post:
Old 11-29-2020, 00:52   #10 (permalink)
Member: 1658652
Thanks Meter: 9
is there any solution?
Old 11-29-2020, 09:50   #11 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,033
Hello. The problem can have various reasons. So the easiest way to reinstall windows.
Old 07-24-2022, 04:25   #12 (permalink)
Crazy Poster
Member: 2770461
Thanks Meter: 22
Just go to the z3x installation folder and delete it. then reinstall. this can be caused by a bad installation of z3x.
Page generated in 0.25900 seconds with 8 queries
